Top Mounted Starters Can I see some pics?
Results 1 to 14 of 22
    Senior Member cave's Avatar
    Mesa, AZ
    Default Top Mounted Starters Can I see some pics?
    I 've had some starter problems and to replace the starter I need to pull the engine almost out. I seen Cruzers top mount on his Daytona (Nice Boat by the way) and that seems to be the trick install for a tunnel. Anyone else have some pics of there top mounted starters?
    Any other info would be appreciated.
    cave
    Takin it home
    Here is mine.
    Senior Member cruzer's Avatar
    Chandler, Az
    Cave
    I don't have much in the way of pictures on the computer but you can come over and take all the pictures you need.
    Cruzer
    21 Eliminator Daytona. Blown 540
    Mesa, AZ
    Your set up is kick a$$ Cruzer. I'm going to do something in November. This pulling the engine stuff sucks
    Takin it home
    Senior Member jet454boat's Avatar
    mesa az
    cave i have a top mount starter bell housing ill check it and see if it is bbc
    The Right Coast/SE-PA
    Cave, I have a 3-point engine mount/bell housing so if you're looking to use a rail mount my set up will not work.
    Mesa, AZ
    Thanks HammerDown. Yes I do have a rail set up.
    jet454boat Let Me Know.
    H20MOFO My bell housing is simalar to yours. Do you know the barnd of housing you have?
    Takin it home
    Chandler, Az
    Cave,
    If you already have the rail kit, all you need is the correct bell house (or modify yours) and the spacer for the starter. I would volunteer to take mine apart for you to copy if you wait until winter.
    Cruzer
    mesa az
    cave if u could send me some center to center bolt measurements, i have a 454 but its sitting on a engine stand and its a pain in the ace to get it up and down with out a cherry picker
    Angier, NC
    hope this helps
    Cave I got it from Tom I belive it's a lightning set up. I know the starter stand itself is a lightning.
    CAVE...this is the best I can do.
    Mesa, AZ
    Cruzer I'll take you up on that offer.
    Man You weren't kidding HammerDown. Thats a tight fit!
    jet454boat Let me know.
    Thanks every one. I put a more heavy duty Starter in last night. I'm freaking sore all over!I definitely want a top mount in there. I found that the New but old starter had some water damage in it. It may be the water that seeped through the packing. It was real loose at the packing bolts. At 4700 rpm I get a tad bit of water coming threw.
    H2OMOFO your Bell housing looks like mine. What brand is it?
    Thanks again to all that posted picks. It look doable.
    cave
    Takin it home
    Is yours a lightning?
