hardened shaft bowl end wear tolerance
Results 1 to 2 of 2
    Sep 2011
    Default hardened shaft bowl end wear tolerance
    Does anyone know the wear tolerance of the main shaft, the end that rides in the water lubed bowl bushings ?
    ATM
    ATM is offline
    Amerian Turbine Man
    Clarkston, WA.
    Default Shaft tolerance
    Quote Originally Posted by 525SC777 View Post
    The factory size is 1.122-1123". The shaft has .005" hard chrome. If it measures less than 1.119" it needs to be replaced.
    Don't let anyone sell you a shaft that is not hard chromed.
    Ron
    One less DEALER means more DISCOUNT for you
