Got my Pyle back on the water
Results 1 to 8 of 8
    Senior Member cave's Avatar
    Mesa, AZ
    Default Got my Pyle back on the water
    My winter project is done
    Pump got some love too. THX Tony Skagen for the Inducer
    Special Thanks to Brian Bergeron of Bergeron Engineering. Brian cut the shaft replaced the bearing and got it to me in just an hour. Great Local service!
    The end result of all of this,
    Takin it home
    Sounds nice, looks nice too! So, maybe I missed it, but what happened to the motor? I know you've had it apart a couple times, did you exercise the Gremlins?
    Mesa, AZ
    I sheared the 3 cam gear bolts last July 3rd. I imagine the 3 bolts were over torqued. Gen 5 and 6 do not offer a cam bolt retention plate. I made one for this build. Bent the tabs against the bolts and added red loctight too. A bit of overkill. When this happened it took out 1 valve stem and of coarse the main bearings and cam bearings too. I replaced all the bearings, rods too. Had the crank inspected & ground down a bit along with the caps being repaired and then line honed. Just in case. Picked up a tad bit more aggressive cam. Added the HM inducer. Dam it pulls hard. and that's what I was trying to get back. I may not go fast but the boat pulls you back into the buckets hard! Plains instantly. The boats fun to drive again.
    I had to wait on the stud girdle bolts. But finally got it all back together. I just ordered an MSD starter saver. I'm locked out at 30° The boats is hard to start. I'm hoping the MSD part will work. Other than that My winter refurbish is done.
    I believe 460 picked up your inducer right? He may be installing it in a few weeks.
    Takin it home
    Senior Member zacho!'s Avatar
    tucson, Arizona
    So good Cave! One of these years Ill be out there with ya!!
    No, not me. We talked a little about inducers when you were looking at buying one. Glad to hear alls good now. Funny, my motor is locked @ 30* also with a mini starter and so far it cranks like a champ. But my battery cable is less than 3' to the starter, and my wiring is as short as possible.
    Mesa, AZ
    Mine used to start up fine too. Maybe the new cam is making it an issue. I pondered adding a Ford relay. Maybe not. we'll see how it goes.
    Feels good to be driving a boat again!
    Takin it home
    Tyro bought my old inducer, it was a DPS, nice piece, hope it works well for him.
    Senior Member Tony Skagen's Avatar
    Nice job!!!
