Header spacing
Results 1 to 12 of 12
Header spacing
    Aug 2011
    placentia,ca
    Default Header spacing
    I have a couple questions about my headers on my daytona 19'. My headers are about 1/2" from one side of the hull. When I bought the boat i got the headers with it and the boat had a blown motor in it. Is there a difference between a blown set of headers vs. NA headers? I dont believe that i have an extra skinny boat either. I have seen plenty of pictures of Daytonas that can run twisties even and the straight headers like these have PLENTY of room. Hopefully someone can lead me in the right direction.
ID:	222754   Click image for larger version.
ID:	222762   Click image for larger version.
    Member 88hardin's Avatar
    Apr 2012
    Quote Originally Posted by SofaKingFast View Post
    I headertions about my headers on my daytona 19'. My headers are about 1/2" from one side of the hull. When I bought the boat i got the headers with it and the boat had a blown motor in it. Is there a difference between a blown set of headers vs. NA headers? I dont believe that i have an extra skinny boat either. I have seen plenty of pictures of Daytonas that can run twisties even and the straight headers like these have PLENTY of room. Hopefully someone can lead me in the right direction.
    I think its just the style of header my bassetts don't even come close.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Blower headers have bigger tubes.
    Thousand Oaks Calif.
    If those are Basset blower headers they will have 2 1/2" primary tubes with a 4 1/2" collector. They do take up more width in the boat.
    I am looking for a good set of those if you decide to change them.
    Thanks very much.
    The farther the tubes come out before turning up helps exhaust flow. Leave them alone.
    blower headers on a N/A motor robs HP.
    Apr 2009
    San Diego, CA
    I must have a blower penis
    Senior Member tunabiteme's Avatar
    riverside
    I see you have a back seat and your motor looks like it's close to the transom, if the motor can go forward you will have more clearance there.
    Aug 2011
    placentia,ca
    That's true but the motor is in basically the standard position if you want to call it that. The pump has been moved back and there is a standard drive line. The difference between where the motor sits to where it could go would only give me an inch or two total. This is what im looking for
    The Twist headers fit well (with clearance) on my current Tunnel project but the standard style nearly touched the upper edges of the gunnel even with the reliefs molded into this hull
    Aug 2011
    placentia,ca
    Does anyone have a set of twisties that they would be willing to sell or trade? I need to find a set of headers that will fit in the daytona. Let me know what you guys have. Thanks
    Default Header Spacing
    Hello, you have a PM.
    Thanks very much.
