Top speed question?
Results 1 to 13 of 13
Top speed question?
    Member 88hardin's Avatar
    Apr 2012
    Default Top speed question?
    So I'm posting for a friend and he has a Careers Eagle 20.5' open bow jet. We are not able to run it right now due to freezing temperatures but are curious how fast it will run. The boat has a 712 horsepower 496 with a american turbine pump with a an aggressor impeller with a loader and ride plate. So maybe you can give him some input. He does check the forum but still is a newby and doesn't understand how to post.
    Senior Member lupo1904's Avatar
    Feb 2011
    Here weeeeee goooooo, im gunna guess 74 mph
    Apr 2012
    Quote Originally Posted by 88hardin View Post
    It has a AB impeller sorry dang spell check on my phone.
    Anza Valley, Lost Lake, CA
    I'm gonna say 58 mph or there abouts.
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Low 60s
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by Turtle View Post
    I'd say that's pretty close
    Colorado Springs, Co.
    Gotta be faster than that, if the motor is really producing 700+ hp. My 23' Glastron/Carlson CV23 will run low/mid 50s with a stock 429 (360hp) and Berk JE/A.
    1978 Glastron/Carlson CV23; 429, Berk jet.
    My Caliber 1 had a 330 hp 350, almost identical hull. Ran a bit over 60. With 700 hp I would guess 75-80 mph if all is working good and set up. These can be very heavy. Mine rigged was over 4000.
    I'm going with the low 60's crowed. HP can't fix a hull set up incorrectly, and that's a fair size boat in the jet world.
    Apr 2012
    Quote Originally Posted by 86NovaII View Post
    It did dyno at 712 so I guess were gonna have to go freeze to find out lol.
    corona calif
    Default Carrera Eagle
    454 With what they call the Magnum approx. 390 to 400 hp with the same setup will run between 62 to 65 mph, light load of fuel and 2 people in the boat. This boat has a tendencey to porpoise at crusing speeds and Carrera would install a Step and Trim plate that would eliminate the porpoise but would hurt top speed, if you have them on this boat make sure you have them in the up position for good results. If your dyno numbers are correct I see no reason that this combination should run into the 80's
    Well my brothers first jet boat 2yrs ago was carrera eclipse, it had a , 502-502 deal, also had a AT pump, droop, ride plate, HPD, and not sure on the impeller size but it was a fucked up andnanaluminum deal, boat had full interior, heavy boat, yadda yadda, but when we gps's it, it sure impressed the shit out of me! 71.2!!!!!!, yea that's what I thought!
    This guys carrera is going to do 70 at least if it really has 750hp.
    That's my thought.
    Rancho Cordova. CA
    <----My Carrera does 78mph. It is also an Eclipse with a 625-650 horse 496 turning a berk J/G 5500RPM with an A impy and full interior.
