Tunnel ram carb setup
Results 1 to 14 of 39
    Jun 2012
    tulsa,ok
    Default Tunnel ram carb setup
    Dropping in my 468 bbc in my Tahiti 18ft soon,?kb prememium forged small domes, comp 274xm, gear drive, large oval port "291" heads. Around 10.1 comp is what the shop is going for. 500+hp with the head work and work done, on 91pump gas.Looking for 65-70 mph, turning around 5-5500rpm. I found a set of rebuilt 600cfm vac sec holleys and a set of calibrated rebuilt600cfm edelbrocks on ebay same price about 500$. I'm at a loss on how to go about setting up a good tunnel ram setup...any help is appreciated...pics...experience...anything is helping me out. Thanks. Carbs are my weak point.
    Know of any nice clean good carb setups for a good price...let me know.
    "its a shame for a man to spend his whole life, not knowing what his body is truly capable of" :Socrates:
    Jun 2012
    tulsa,ok
    Default Tunnel
    Jun 2012
    tulsa,ok
    Default Carb
    ..carb selections I found and info. Allstate carbs remans
ID:	225466   Click image for larger version.
ID:	225474   Click image for larger version.
ID:	225482   Click image for larger version.
ID:	225490   Click image for larger version.
ID:	225506   Click image for larger version.
    Senior Member eliminator's Avatar
    Roanoke VA
    Back in the day , I use to run a tunnel ram on a mild BBC and it ran great with the Holley 600s . You can fine tune the Holleys .Good luck .
    Spider Monkey Racing
    FRIENDS DONT LET FRIENDS DRIVE EGGBEATERS
    Apr 2012
    if you go with th eddys let me know what rods and jets they are saying are "calibrated". im in a mild 460 with similar build specs as your description. im running the eddys (as thats what was lying around) and they work well here. i had to do a jet and rod adjustment as they didnt work well off the shelf i believe im at 101 pri and 98 sec. cant remember the rod number though
Name:	last one please 047.jpg
    Okmulgee Okla.
    Quote Originally Posted by Krazykracker View Post
    I have never been a fan of "Eddies" or vac secondaries I think I would go with a couple of 650 DPs as the Tunnel rams, in my opinion aren't known for vacuum. I would also recommend loosing the gear drive, and find a good billet double row timing set. I have yet to see any good come from a gear drive set up. If you want it to whine, Blower whine is the way to go.
    well the block is GM any ways
    IS UNDER FIRE
    Junior Member Apache86's Avatar
    Marysville, CA
    i have an apache 18 i have a great tunnel ram setup that has been so dependable im redoing it for my new motor , now let me start of by saying most on here will say , awwww screw edelbrock u need holleys , not so , the apache did 88 to 92 all day long and i have time slips to back that up , i went with 2 1407 edelbrocks, pulled all the choke assembly off right out of the box, they come with 107 primarys and 113 secondary jets, i took the 107s out and put the 113s as the primarys, and bought 120s for the secondarys then took the stock stepup spring out , (they are color coded) i thing stock is orange , , and replaced it with the silver one which opens the secondaries sooner, its been a tried and true combo for 5 years ,its an animal off the line , (no stumbles or hesitation) just my 2 cents they are inexpensive and easy to work with ,, hope this helps .GET MECHANICAL SECONDARIES VACUUM WONT WORJ WITH TUNNEL RAM hence the 1407 part number
    Senior Member bc18's Avatar
    Check out my add in parts spam
    Jun 2012
    tulsa,ok
    Thanks guys...I'm appreciating the input. Guy uptop asking for calibrations....^ this guy might of answered your question. He said what he did his calibrations at...I feel on the street eddies are great I have always ran them. I just haven't had a tunnel ram so It's a new adventure for me. Anything special need to be done on hooking them up..or just block all the plugs off ..? Any vacuum just have to be hooked up..?
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    Quote Originally Posted by Apache86 View Post
    Damn! that thing is aired out!!!
    Apr 2012
    i did read that. the 1407 is a 750cfm though. the 1405 is a 600cfm. i would assume its a bit different in jetting with almost 300cfm combined of more air
    Jun 2012
    tulsa,ok
    i maile the reman company and aske the calibration on the 600cfm setup, ill pass the info along to ya
    Senior Member wolfie's Avatar
    I'm not sure about what others have experienced, but while researching I found that gear drives are not good for sustained high RPM engines. Either a double roller or belt drive is better.
    I like Edelbrocks, but on street applications. I like my Holley 600CFM Double Pumpers on my wife's boat.
    Maple Ridge B.C. Canada
    Quote Originally Posted by Wild Hair View Post
    x 2 ! my 2 650 dp's work great on my t/r . in my opinion vac sec are for trucks
