For you nitrous guys
Results 1 to 14 of 26
    Tacoma Wa
    Default For you nitrous guys
    How are you all controlling your bottle pressures out in the river with the extreme temperatures?
    Lost Wages, NV
    I was going to run a NX Fire & Ice controller in my TA. Uses a heater element to warm and a peltier device with a fan to cool. Has a pressure transducer to know how much psi there is, then works the heater or cooler to maintain a 5psi window.
    http://www.nitrousexpress.com/Catalog/2008/fic.pdf
    Keith-
    Tacoma Wa
    How hot are those heaters getting the bottles? I would assume for the heater to work it would have to get the bottle hotter than sitting out in the sun at the river, which would get it pretty hot too... I guess I would have thought that keeping the bottle cool at the river would be the tough part.
    Beach towel put in the ice chest then place on the bottle. I have a friend that use to place his bottles in the sand in the water with a towel over them it seemed to keep them cool enough even on the hottest days.
    Sleeper CP
    Tacoma Wa
    I was giving some thought of a cooling system, using river water and some sort of either water filled blanket or coils to keep the temperature down on the bottle. Of course it would only work if the engine is running, unless it was designed as a closed loop.... I would hate to grenade my engine because of a pressure spike due to temperature.
    Just run your fuel pressure a little on the rich side , typically the plunger will stick before it will overdose the engine with nitrous.
    Use the saftey systems.
    Sleeper CP
    B1 Racing cs19's Avatar
    First of all do not trust those little bottle guages, they are a joke. I recently bought a 5" diameter 1% guage for bottle psi. Last weekend at the races almost all of my small bottle guages were off, some as much as 300 psi. I was running a rather large system so I made sure my bottle psi was right on for every pass. I would either throw the bottle in my cooler with the large guage connected or I would take the bottle down the the lake and leave it in the water for a minute or so to get the bottle psi down. When its cool out I warm the bottle in the truck for a while and I run a bottle heater in the boat, I heat the bottle to 1050 on the holding rope then purge down to 950-1000 so I have liquid waiting at the solenoids. Only drawack to the heaters are they are hard on the battery.
    If your going to use one of those little bottle guages make sure you never peg the guage, what happens is the guage pegs then skips a tooth inside the guage and it will be a few hundred psi. off from that point on.
    If your at the river and it gets way too high take the bottle out and put it in the water for a while, it will cool off. A purge is a nice thing to have also to drop the psi a small amount.
    B1Racing.net
    no need 2 fake it. 84Condor's Avatar
    Yuma, Arizona, United States
    not to hi-jack your thread bro, but i have nowhere to mount a bottle in my boat except for back by the headers... im thinking that it'll build up too much heat back there and blow the pop-off on the bottle.. but im dying for the bottle haha! any suggestions? i guess i could always take out the back seat... hahah
    Tacoma Wa
    have you looked under the boat with a remote valve?
    ~Brian
    what do you mean under the boat? i got a tunnel hull if that makes a difference
    Quote Originally Posted by 84Condor View Post
    just have the passenger hold the bottle, when you want to go faster have them point the bottle at the scoop and crack it open...this should work fine for you
    Tacoma Wa
    Sorry meant under the bow....
    Quote Originally Posted by blue wonder View Post
    only if you're the passenger tony!
    The two bottles in our boat are tucked up next to the drivers seat and passenger seat. The bottom of them butt up against the fuel tank. Someone on here took pictures of where their's was mounted and the bracket look just like mine.
    You can build a mounting pad and mount a bracket to it under one of the side's of the boat.
    Sleeper CP
