Where to buy Tanks for Daytona 21?
Results 1 to 12 of 12
    Senior Member stewvette's Avatar
    Nov 2009
    Default Where to buy Tanks for Daytona 21?
    I'm looking to buy some bigger gas tanks for my 21 Daytona. Does anyone have some stock tanks lying around they would like to sell or know which company i should call to get some made? I have the round gunnel tanks in there now they only hold around 13 and start sucking air on deceleration when there a little less then half full. Not giving me much range out here on the CA delta.
    F14
    F14 is offline
    Senior Member F14's Avatar
    Dec 2011
    Nor Cal
    I would think you can buy them from Eliminator Boats. My 92 21 came from the factory with 25 gallon tanks per side. I think that is the way they currently make them.
    Sep 2011
    Los Angeles
    Either check with mouzer on the forums or give imco a call.. They custom made me 2 10 gallon aluminum tanks that were $700
    Hit it where you fit it
    Santee Ca.
    The last couple of 1995-1999 21' Daytonas I have owned had tank made by Lightning MFG. I have no reason to believe they were not the original tanks and I feel that is what they were rigged with when new. 24-25 gallons each and built from aluminum if that helps.
    Outboard and Jet verions had the same tanks in my case.
    San Diego, CA
    Original tanks were made by Lightning MFG. Give Jan a call and see if he can help you out.
    Here is the link - Home
    Boat 405.
    Aug 2011
    placentia,ca
    i might have some 8.5 x 64" russell stainless steal tanks with senders for sale. They are 15 gals each.
    Clovis, Cali
    Is that just for the newer style hulls ? Both of my early style hulls have had round stainless steel Russell tanks (23 gal each).
    San Diego, CA
    Quote Originally Posted by propless View Post
    He used to make lots of different tanks for a variety of manufacturers, exactly what boats he did do and didn't do, I don't know, but I'd call him and see if he can help out.
    Boat 405.
    Nov 2009
    Thanks guys ill give him a try.
    Anaheim Hills
    IMCO Marine in San Dimas CA. Pretty hard to beat their quality. You can mail him a template or drawings of what you want.
    Ask for Steve and tell him Dennis sent you.
    click here:
    Home page
    Member 78hallett's Avatar
    Jul 2012
    Norcal
    Quote Originally Posted by SofaKingFast View Post
    PMed you
    Senior Member boatn247's Avatar
    Feb 2009
    lake havasu
    tank it in Lake Havasu 928 505 2030 will make custom tanks hes done a lot of work for me and is reasonable.
