engine help
Results 1 to 11 of 11
engine help
    Senior Member beerngasoline86's Avatar
    hacienda heights ca
    Exclamation engine help
    just built a 528 chevy and having some gnarly knocking on one side it sounds like a loose rocker or miss adjusted but its not! AND it started making a dry skretching sound so i cut it off?? any ideas of wtf it is??? or aany builders got any spare time to help me out i got cash!
    Lexington, KY
    Exclamation
    Post this in the "On the Dyno" section as well. That's where a lot of the engine builders hang out. This will better your chance of getting a proper diagnosis.
    Good luck.
    HJ
    East Side
    If metal is knocking there is going to be signs of it somewhere. Are you having rocker clearance problems?
    hacienda heights ca
    no no clearance problems... the engine was running when it was in the southwind, took it out and put it in the cp and having major complications with it now..
    East Side
    Quote Originally Posted by beerngasoline86 View Post
    All you did was switch boats? Are you sure it is the motor and not the jet pump? Does it make the noise if you turn it over by hand?
    with your ol lady
    If you sat the engine down on the pan while doing the switch you could have pushed the pan up against the oil pick up and now its not getting any oil. Not saying you did but i've seen it happen before. Can you tell where the knocking noise is(top, bottom,left/right side) ???
    No more Mr. Nice Guy !
    hacienda heights ca
    the noise gets louder at a higher rpm... and i was about to say thye engine was on a stand the whole time it was being built but i sat it down real quick to reposition it on the hoist that could have done it...but what about the knock???
    with your ol lady
    When its running does it have oil pressure ??? If your positive the knock is comming from the engine I would pull the oil pan and check the rod bearings. While the pan is off, mite as well check the mains also. See what the oil presure is first but dont run it very long as your doing more damage if its not getting any oil.
    Engine junkie
    Thermal, CA
    Check for a starter, flywheel, bell housing interference problem first, do the same around the alternator and balancer, look for anything that is hitting. I have seen this problem before with starter to flywheel problems. Thats of course all based on you having the correct oil pressure.
    Life's journey is not to arrive at the grave safely in well preserved body, but rather to skid in sideways, totally worn out, shouting"....holy shit.... what a ride!"
    hacienda heights ca
    verdict is a connecting rod bearing...so bummed butt at least i no what it is...
    with your ol lady
    Have you figured out what was the cuase yet ? Oil pan to pump clearance ? Just wondering. Atleast it didnt come apart in lottle pieces.
