never seen this before.........
Results 1 to 14 of 36
    Senior Member LOLYFE's Avatar
    Idaho
    Default never seen this before.........
    This is an imp just pulled out of a lady friends 21 cruiser, complained that boat made a lot of noise but did not go anywhere ,(kinda like RCL) had pump "supposedly" rebuilt last summer about three trips to lake. Has a 9.5 installed ( got me on that one? ) not sure what brand, aluminum A. Cant imagined what happened here, Ideas?? never seen one this bad, imp still looks new. Maybe let run too long on trailer?
ID:	233922   Click image for larger version.
ID:	233930   Click image for larger version.
    The Right Coast/SE-PA
    Maybe from shock > loading/unloading the bump at high rpm.
    Not sure if those grooves are result of debris...or...some pump-shops lath them in to make 'water-o-rings for less blow-by.
    I've read the above procedure is a waste and does nothing > Seloc Marine Jet drive' Seloc's Marine Jet Drive, 1961-1996: Tune-Up and Repair Manual (Marine Manuals): Joan Coles, Clarence Coles: 9780893300296: Amazon.com: Books
    seattle
    I have seen that when the bearing goes out...
    This type damage can manifest from several conditions and the galling between Impeller and wear ring is like a snowball rolling down hill, may have started with a simple grain of sand amoung other things noted , whats the wearing look like what material assume there is metal transfer? any pics
    Default Very front...
    Quote Originally Posted by 1975sleekcraft View Post
    Normally when the bearing fails the impeller is shoved forward and damages the very front. That impeller is damaged behind the front "lip" which would seem to be caused by running off center. He didn't show the wear ring or the suction housing, so it's hard to say what caused what, or what area failed first....
    Ray
    LOUD BOATS SAVE LIVES
    Senior Member Mojave85's Avatar
    Boise, Idaho
    What are the chances the shaft is bent? I would think if it was out of round (even just a little) it may cause problems like this.
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    Same thing happened to one of mine one summer. My buddy took it out but did not (know) there was a sand bar under the boat chugged through it.
    BIG member Marko's Avatar
    Feenix
    I think Grainger's sells parts for those things.
    Quote Originally Posted by Jetboatguru View Post
    Ok that is why you belong in a kitchen and not in a flat bottom.
    Oct 2010
    Lake Dallas TX
    Check the wear ring for nicks from a punch..... got one did the same.
    Shell Knob, MO
    Looks like your buddy got a hold of this one too.
    If it were from running with a bent shaft, it would be a more one sided wear pattern. Rule that one out.
    If it were a Failed bearing, the front would be gone like mentioned above, rule that one out too.
    If it was from running off center, we could tell by looking at the wear ring. but kind of doubt that one.
    That could also be from dragging it down the road without the pump opening covered and then fireing it up on the trailer, or the old sand bar trick. Like Tom said, once the damage is started the metal galls and rolls up in balls very quickly.
    Wear Ring Picture?? Please!
    seattle
    Quote Originally Posted by APOLLO View Post
    if this was done by a sand bar.... I would think those impeller blades would be semi-polished...some where on them... They look pristine ..........
    Idaho
    more pics of wear ring and end of shaft, one bowl bushing had pushed seal out and bushing out too, a lot of this looks like no maintenance, running it in sand/ gravel, galling of imp to wear ring. Has non shouldered wear ring, bearing still in original form, lacks grease, imp did not dig into suction housing, had about .50-.60 clearance between imp and suction housing face
ID:	234362   Click image for larger version.
ID:	234370   Click image for larger version.
    Idaho
    one more
    Shell Knob, MO
    Yep, rule out the running off center too.
    if this was done by a sand bar.... I would think those impeller blades would be semi-polished...some where on them... They look pristine .......... .
    Exactly, rule that one out too and tell the customer, (or friend), to please cover the intake of the pump while towing and DO NOT run it on the trailer any more.
    Duane HTP
