What size Aluminum tubing for water lines? Bassett T AN size?
Results 1 to 8 of 8
    Jul 2011
    Default What size Aluminum tubing for water lines? Bassett T AN size?
    What size are the AN fittings on the Bassett T? What size is the AN fitting going into the header water lines? What size copper or aluminum do I need to buy to make water lines (from Bassett T to the header lines? Pictures would be great also.
    I guessing AN8?
    Mar 2010
    Clarksville, TN
    -8
    thats what i run.
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    you should use stainless steel tubing for everything.... from the headers (if thats what your talking about) Those should be 1/4" tube. Then the connector of the header water lines to the TEE are both typically -8 AN (or 1/2" Tube) but you can run 3/8" tube with adapters on the ends to -6. You need to remember that the ID of Tubing is greater than the ID of Hose because of the wall thickness. So smaller is actually bigger.... with Tubing. hopefully that makes some sense to you.
    Senior Member jrider44's Avatar
    Brainerd, MN
    Default AN sizing
    If you are unfamiliar with AN sizing, an easy way to remember what fractional size the AN number equates to is that everything is in 16's of an inch. Therefore 8AN is 8/16's of an inch or 1/2. 4AN=4/16 or 1/4inch. 16AN=16/16 or 1 inch. And so on. Probably not what you needed but hopefully a help to someone.
    1978 Hawaiian Party Cruiser
    Stevens V-drive(sold to bbollig55)
    Spico V-drive
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    There is an AN chart in the stickey of the dyno section.
    QE 439 Twin Turbo
    Jul 2011
    Quote Originally Posted by jrider44 View Post
    Thats very simple and helpful
    Brainerd, MN
    Quote Originally Posted by stuntgwis View Post
    I checked out the chart, great link and information
    Spico V-drive
