Push Button switch
Results 1 to 6 of 6
Push Button switch
    Denton, TX
    Default Push Button switch
    Does anyone know where to find an illuuminated ON/Off push button switch? Everything i found online is elevator size. I'm looking for a smaller unit.
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Did you already try Grainger or McMaster Carr? they got everything all kinds of sizes
    Quote Originally Posted by 72Hondo View Post
    Silver Metal Stainless Steel Red LED Illuminated Momentary Pushbutton Switch 22mm:Amazon:Electronics
    Or do a search in google for iliuminating momentary switch.
    Denton, TX
    Quote Originally Posted by Woods 017 View Post
    Those are the types I am finding. I think those are a little big, I am going to mount it in the dash. I have a push button switch in there now but it needs 28v to illuminate (aircraft switch)
    LaGrange GA
    on 3 go..... Slow Burn's Avatar
    Aha - SoCal.
    Omron Electronics sells the 16mm diameter switches, 12-28VDC, all colors and styles with IP65 rating (water restant) #A165-_ _ _
