Forward / Reverse Lever
Results 1 to 3 of 3
    Junior Member mcvette's Avatar
    Sep 2012
    Default Forward / Reverse Lever
    This is a dumb question but figure I better ask to be sure I'm doing it right.
    I am installing a new forward / reverse cable and shifter. Not the easiest thing to get too. Here's my question. When the shifter is straight up it is also in the forward position since there is no netural position.................correct.........and you push the lever back for the reverse position. Is this correct?
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    I like straight up to be the reverse/neutral and foward 90 degrees (3 o'clock postion, toward the bow/dash)
    x2 so its out of the way while making a pass.
