calgo steering
Results 1 to 14 of 24
calgo steering
    Las Vegas, Nv
    Default calgo steering
    Can Anyone explain how the calgo steering cables are routed and held in place along the gunnel of the boat? Any one have pictures of their insallation inside the boat?....H
    Concord, CA
    Default routing
    I screwed in some plastic wire loom holders to the inside of the gunnel. Keeps everything supported and out of sight.
    In the past, I fibre glassed some round tubes into the gunnels to support the wires and steering cables.
    Jerry
    IBEW Local 569 Blown Income's Avatar
    Yeah what he said. Mine are also in plastic clamps, not high tech but if it works don't F with it
    Las Vegas, Nv
    On a jet calgo ,do both cables exit out the same side of the hub,or are the jet and vdrive hubs the same where a cable exits out oposite sides?
    I have tried to find insallation info and pictures of a jet setup especially the hub,but all I find on rex and the like are the v-drive set.
    I bought a used setup ,but I think it is for a V-drive.If it is ,it might be for sale soon....H
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Hal, just go rack and pinion. So much easier. LOL
    Wags
    Senior Member Nailhead's Avatar
    Castaic Ca.
    Jet cables exit out the left side
    Las Vegas, Nv
    So this one is for a v-drive then?
ID:	12915   Click image for larger version.
ID:	12916   Click image for larger version.
    Lexington, KY
    Question
    Why wouldn't it work for a jet, too? Why would there be any difference in the steering hub?
    Thanks.
    HJ
    Vacaville,Ca.
    That style Calgo will work, it will require a different pully setup.. I'v seen them on Jets & OB's..
    Bullhead city AZ
    I had that steering in my Bahner when i got it..........I took it out and i put in a rack & pinion
    2sav
    Parker Az. / Burley Id.
    I know there are several people that think calgo is a great system, and have had good success with it. I have had fast boats for over 30 yrs. and have circle raced jets and flatbottoms etc. While driving probably 75 to a 100 race and pleasure boats, I have had 4 steering failures, all have been clago. In a well maintained race situation it is probably a good system, however I will never drive or let my family ride in a boat with calgo. There are too many things that can go wrong with the set up and cause problems, and you never know who had there fingers in it. Not trying to slam calgo but I wouldn't use it in a pleasure boat.
    Castaic Ca.
    I wouldnt use that until you had it rebuilt. Its a few hundred to get them rebuilt. I bought a new set-up with the 9" post that will be going in my jet.
    Vacaville,Ca.
    Using one of these & a tiller arm setup is the best...steering box runs about $650.00.........
    Lexington, KY
    Lightbulb
    Everything about the Calgo steering system is very expensive. If it were me, I would take the money I would save by using a regular rack and pinion, and buy some other parts for the boat!
    HJ
