JC Split Bowl???
Results 1 to 14 of 27
JC Split Bowl???
    Lexington, KY
    Question JC Split Bowl???
    This has baffled me for a while now. How is a Berkeley JC bowl converted to a split bowl? Is it just cut off, until you get the right diameter for the adapters? I would think that this would look really funny. Are there any advantages to doing it, over buying a JG or JB bowl? Can I see some pictures of a converted bowl? And about how much does it cost to have it done, and who does it?
    Thanks.
    HJ
    Nechako
    was wondering the same thing myself . there was a picture of one posted on here back a quite a while ago . i'm thinking you have to weld a ring on first then machine the flange as there just isn't the material in the original casting.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    c bowl
    converted c bowl
    the bowl is cut and a new flange is welded on. I believe the one pictured above was done by Jim at e-performance marine.
    http://www.e-performancemarine.com/
    The c bowl is considered to be a better bowl due to the vanes being longer than the B or G bowls.
    At the time MPD was the place to have the C to G conversions done, it's a lot of work to do the process correctly, so it's somewhat expensive. We had one done about 4 years ago by MPD, cost was in the $450 range, don't remember if that was just for the bowl work or other work done. Today the prices of jet components are relatively cheap compaired to just ten years ago. Today a new style bowl with longer vanes can be bought for just a little more money.
    Lexington, KY
    Question
    What are these newer style bowls? Are you talking about bowls like Aggressor's or AT's? Like this bad ass Aggressor 11 vane.
    Thanks.
    HJ
    Not just Aggressor, Dominator, and American Turbine as well.
    Lexington, KY
    Talking
    Alright, the only one I forgot to mention was Dominator (and they're made by AT).
    But, are there any advantages to getting the conversion, over buying a new bowl.
    Thanks.
    HJ
    El Cajon, CA.
    I think you're splitting hairs in comparing a converted JC to a JG or even a newer AT, etc., etc... I would think for the average non-race jet boat the differences would be minimal.
    Now we just need an informed person to tell me why I'm wrong.
    Lexington, KY
    Talking
    I'm just trying to figure out which bowl would give me the most thrust with my low horsepower, low rpm engine. And having the ability to add and remove hardware, like a split bowl, would be nice too. I need all the help I can get with my small motor. I'm just glad the boat came with an impeller that works well on low rpm engines.
    Thanks.
    HJ
    Thanks.
    If you want the biggest bang for the buck, on your pump...Get your impeller race prepped and a new matched wear ring. After that you will need more HP
    Prune-Picker
    Calif
    Just curious. Why do you say that bowl is bad ass??
    Cs
    Lexington, KY
    Exclamation
    My impeller looks like this (see images below), it is an aluminum AB cut of an unknown (to me) make, it started out as an A2 based on the stamping on the back. It came with the pump when it was sent off to be rebuilt (before I bought the boat) and blueprinted. It also has a bronze shouldered wear ring that came with the impeller (I guess) from whoever rebuilt the pump the first time. (I tore the pump down and rebuilt it when I got it, but it had only been run a couple times before the boat was sold, I just replaced the gaskets and speed coated all the interior surfaces of the pump) Is that a race prepped impeller? Cause I really have no idea.
    HJ
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    There was alot of talk about this on hotboat, i had my bowl converted by MPD. Think it ran me 400 bucks and he only does certain times of the year when he's not busy. Go onto hotboat and do a search.
    somebody's detailed that impellor, looks nice.
