will impellers interchange
Results 1 to 11 of 11
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    Default will impellers interchange
    Will a berkeley impeller fit into a dominator pump? I think the only difference is the lip around the back side of the dominator impeller, is this not needed?
    Thanks, Ryan
    berk impellor will fit a dom pump but you're losing efficiency doin it. the dominator impellor has a bigger o.d. which keeps the pressure at the back of the impellor better. you put that berk in there , its smaller o.d. will allow more water to reach the wearring at a higher volume best way to describe it is a berk a impellor in a dominator bowl will work like a dominator b cut, yet won't move near the same amount of water the dom impellor with the bigger diameter will. hope that helps , not confuse
    Senior Member Futs's Avatar
    Orange CA, Big River
    HUH????
    HUH????
    lmao, i knew i was gonna confuse someone the dominator impellor has a larger o.d. than a berk, lil over a 1/8th inch wider at the widest point of the impellor you put that berk in the dom bowl, more water flow backwards in the bowl than it should. set a berk impellor next to a dom impellor and you'll see what i mean
    i've got a dozen old impellors in my shop , few doms, but i don't have my big calipers here to show the difference, but there is a big difference.
    I was just messin with ya....
    well hell, i made better sense of it in the 2nd post anyways,lmao
    i've met alot of guys jetting 20yrs that still don't know there's a difference between dom impellors and berk other than the stuffer ring. my mom(uncle and some buddy's did as well) worked for dominator as a pump assembler when dominator was in hugo okla and she can tell em all bout it. wish they(dominator) were still here i've got a shit 12s suction housing with the hugo metal tag on it i keep around to remember the good ole days.
    And here I thought AT was the only one running the stuffer ring. Learn something new everyday.
    Now here's a question...will Dominator impellers fit an AT bowl without any machine work?
    isn't the a.t. just a tad longer version of the dominator bowl? i would say yes, we just got a new a.t. bowl from tom @jbp and a matching a.t. impellor, and the a.t. impellor fits nice in my dominator bowl.
    Lexington, KY
    Talking
    I would hope so, doesn't AT make Dominators.
    HJ
    it wasn't always so dominator jet drive used to be within 10 minutes of where i sit now.
    Lexington, KY
    Red face
    Oops, my ignorance is showing.
    HJ
