JC pump
Results 1 to 13 of 13
JC pump
    Senior Member TahitiRat's Avatar
    Fort Worth Texas
    Default JC pump
    Can you just bolt a split bowl (I think a JG bowl right) on a JC pump or is the any work required first Thanks
    Straight bolt-on.
    Fort Worth Texas
    Cool thanks. Also as I under stand it the main advantage to a split bowl is that you can put a droop or a wedge in the nozzle is this the only advantage or is there more to it than that Thanks Eric
    Quote Originally Posted by TahitiRat View Post
    That and it looks cooler than a JC bowl
    Thats what I did to mine...changed over from a JC to an AT/Dominator split bowl setup. I have yet to put the droop on yet though.
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default Snoop and a wedge!
    It lowered my line of thrust. Freed up the hull a little. (could be psycho sematic, though)
Name:	'08 boat pictures 061.jpg
ID:	13239   Click image for larger version.
Name:	'08 boat pictures 096.jpg
    Quote Originally Posted by Schi-502 View Post
    Out of curiosity, what's a snoop?
    One part at a time... JohnnyNitrous's Avatar
    Surrey, BC, Canada
    A rapper!!
    Fort Worth Texas
    Thanks to everyone for the help I thought that this was the case but wanted to make sure I wasent mising something thanks Eric
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    What you want to do is convert that jc to a jg. A jc has a higher gpm rate of flow compared to a jg and when this is done the jc is longer than a jg, 1 inch, which puts you closer to an agressor bowl. Agressor good . And the fact to a jc intake differs from a jg intake another bonus.
    ___________________________________________
    ___________
    "Chine walkin: (verb) - to show another brother that you will stay in to win. (syn.) Holy *hit!!!!!! Don't Lift!!!!!"
    El Cajon, CA.
    ... And the fact to a jc intake differs from a jg intake another bonus.
    What's the differences?
    AZ, Queen Creek
    They both use the same style lodaer gate flange but the jc intake is a little longer than the jg so the jc intake doesn't isn't as steep inside as a je so the water tends to flow a little freeier. The only way to tell a true jc is look at the serial number on the pump and around the intake four loader bolt upraised material and they should match. I believe the jc intake starts with a h serial number.
    ___________
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    I'll have to go out later later this week-end and measure mine, I'll have both here on Sunday.
    Wags
    AZ, Queen Creek
    And if you got em both out and going to put one in definitly sand, deburr, smooth. It's the little stuff thta adds up plus you can be like some...."Ya ya I gots a detailed intake." ha ha . Its in the details.
    ___________
