Bowl Pressure tap locations
Results 1 to 14 of 24
    Southwest corner AR
    Default Bowl Pressure tap locations
    For checking pressures on the intake where is the best locations to tap the holes? Pic.would help alot also! Thanks WT
    check the shoemaker section, we had this discussion a couple weeks back over there. i've got 3 taps on my housing but i only use the rearmost. its at 9 oclock , 1 inch in frt of the wearing boss, as far behind the inducer as i could get safely. its reading the average across the face of the impellor pretty consistently, the gauge doesn't flucuate at all until it cavitates
    Southwest corner AR
    Thanks Tom I will check that thread out! WT
    Default 10 and 2
    Here's mine still haven't plumbed it. you can still see all the drill shavings on my ride plate. lol Edit; I don't know what I'm smokin that ain't 10 and 2 lol
    i've also got those taps, but since the inducer skews loader and shoe readings by that point, i settled in between them on the opposite side just to take an average of the 2.
    Southwest corner AR
    But what I read that Greg was saying is 10 and 2. That would put them all on top would that not give you the loader pressure for the bottom of the impelor??? WT
    Lexington, KY
    Question
    What's the point of running a fin, when there's no material there to actually do anything??? Seems kinda pointless to me!
    HJ
    The mini rudder dealio is also my bottom pin. It didn't look right to me because the droop isn't as thick as the stock piece,and now more of the pin is exposed. I e-mailed that picture to Tom JBP and he told me it looked like part of my rudder was missing?
    directly quoting shoemaker's 1st post in the "pressure thread'
    "Being that I have never installed a tap in front of the inducer I would still try to tap behind the inducer."
    if you're looking at your pump from the inside and reallly start to burn your brain about what's happening at the inducer as the shoe pressure and loader pressure hit it and spin around, i really don't think anyone can come in here and claim that taking readings at 2 & 10 behind the inducer is gonna be accurate unless you pulled out the inducer, then tuned, then stuck the inducer back in. just sticking the inducer back will change soo much, how the hell could anyone say it was accurately reading shoe and loader anymore at 2 & 10 with a inducer? really wish someone could make sense of that for me, i'd really like a pro opinion on it but all i've gotten to date is vague opinions on the matter. i'm no hydroengineer, i just do what makes sense to me and hope it works,lol.
    Lexington, KY
    Exclamation
    Part of your rudder? Try the whole thing! Here's what it is supposed to look like. If the pin is too long, you could either get another one, make a new one, or cut the current one down. Hell, I have a pile of pins sitting on my bench, I could send one out to you if you really want. My diverter came with the short pin, so I took the long pin and rudder I had on my prehistoric PD, and put em' on my new PD. They are exactly the same, thanks PD for not changing the design very much over the years.
    HJ
    I think rudders are optional.
    Lexington, KY
    Talking
    That's why they sell it as an "accessory" and you have to pay extra for it. But hell it can't really hurt the performance very much, can it?
    Good luck with the boat, looking good!
    HJ
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default Rudder vs no rudder
    I bought the boat in pict. #1 condition, then added the snoop and rudder. Boy that was an "E" ticket ride! Then I removed the rudder altogether. Works fine as is.
Name:	Our boat at Lake Berryessa 001.jpg
ID:	13234   Click image for larger version.
Name:	'08 boat pictures 064.jpg
    Default rudder
    I keep the rudder on my ski boat because I think it may help when the skier swings way out on the sides and tries to pull the boat sideways. I know it hurts speed but hell, who wants to ski 75 anyway?
    the ski boat is a condor vee bottom with a 557" BBF.
