Sleek craft SST rigging help
Results 1 to 14 of 29
    YOUNG BLOOD Dean Corinth's Avatar
    Jun 2012
    California
    Default Sleek craft SST rigging help
    how do some of you guys have your SST tunnel hulls rigged. what did you use for engine mounts? any tips or suggestions for building one? what would you guys do? or would like to have done to yours? thanks.
    MI
    Glass some stringers in would be a start.
    Senior Member kidd bill's Avatar
    Silverton,OR
    I wish I would of just put stringers in mine but this is how I did mine. Name:  188.jpg
Size:  15.6 KBName:  181.jpg
    bullhead city
    this is how I did mine for now
ID:	266697   Click image for larger version.
ID:	266705   Click image for larger version.
ID:	266713   Click image for larger version.
    Senior Member 79sleek's Avatar
    May 2011
    Wyoming
    Quote Originally Posted by hihosilver View Post
    Did you through bolt yours through the bottom of the boat and use carriage bolts? Could a guy do a 1/4 stringer set up to hold some good power say 800+horse power?
    Chrome ALWAYS gets you HOME!!
    Silverton,OR
    Mine is through bolted with countersunk fasteners and a aluminium back up plate on the bottom side. Mine has held up just fine with upwards of that 800 number. Stringers would just make for a easier and more conventional install. Not sure if there would be any structural or ride benefits cause its a tunnel and the heavy lay ups used in these boats.
    Jun 2012
    California
    Kidd bill, my dad likes your set up, we might just have to steal the idea of your set up. thanks for the replies guys. i appreciate it.
    Dean this is the method used on ours (prior) however were are designing a rail kit type system to replace it Tom
    bullhead city
    mine is thru bolted, no backing plate with 550 hp second year of running this way, it does feel stiffer than before but someday would like to do stringers and rails and setback pump like tom said( waiting for him to try first), the pump brace I made helps I think tying the pump and motor to
    MI
    We kinda thought stringers was the best way to go for this deal
ID:	269257   Click image for larger version.
    Silverton,OR
    ^^ Is this a new combination or something that has been ran before?
    MI
    Quote Originally Posted by kidd bill View Post
    This setup hasn't been in the water yet.. Going to be interesting to say the least.
    May 2011
    Wyoming
    Quote Originally Posted by sanger rat View Post
    So did you do full length stringers or just where the back seat would be? I thought about a 1/4 stringer with a cross board at the front of the stringers and a u shape pieces on the transom to help hold them and do a rail kit with motor plates and a plate to hold the pump. Do you guys think that would hold a 545ci kaase headed bb ford 800+ all motor then spray on occasions?
    Silverton,OR
    If your going to go down the stringer road I would just go all the way and do full stringers. My combination spins a A impellor 6300 without stringers and no known ill effects of it. Im currently setting the pump back and adding a shoe and rideplate on mine. Also one thing you might wanna check is the pickup tubes in my tanks were very small, the fitting was decent size but the tube part itself was small.
