Jacuzzi wj pump shaft question
    Senior Member crf311's Avatar
    Meraux, LA
    Default Jacuzzi wj pump shaft question
    Hey guys I have a question about the feel I get when I twist the shaft on my Jacuzzi Wj pump. I had to pull the motor to find a oil leak and while it was out I wanted to feel how easily my pump shaft spun. If spun freely, but when I kind of twisted it back and forth it felt like there was a looseness between the shaft and the impeller. Almost like what you would feel setting the gear mesh on the rear end of a car. Should this be happening or should I pull the pump apart and make sure the nut and keyway are tight? Thanks.
    Senior Member Mash on It's Avatar
    Willow Beach & BHC
    Default WJ nut
    Sounds like the nut loose/keyway wear. or was this on the splines of the drive shaft? Or wear ring missing screws? sounds like time to pull the bowl, at least........ Daniel
    "Never mind the mule, Just load the wagon"
    '76 Eliminator 21'
    Quote Originally Posted by crf311 View Post
    OEM Wjs have a taper fit on impeller/to pump shaft connection , It would be rather unusual for any slack or "play" , if you can rock the shaft back and forth by hand? would suggest a loose or damaged impeller among other conditions Tom
    Meraux, LA
    Thanks guys. I'll have to pull it down and see what's going on in there.
