Anyone with a Classic 21 Daytona on Competitive trailer
Results 1 to 13 of 13
    Dallas, TX
    Default Anyone with a Classic 21 Daytona on Competitive trailer
    How are the inner fenders made? I thought it was just a flat piece of ply wrapped in carpet bolted to the back of the fender. If tried that but the wood is dangerously close to the tire.
    Silverdale, Washington
    Not on ours. It's a flat piece of wood but angled at the bottom towards the boat. 3 bolts at the top of the fender and then 2 at the bottom that bolt to a couple tabs welded to the trailer. I would show you but this trailer is so damn ugly you would laugh.....
    Dallas, TX
    Thanks John. I can picture what you are saying. Mine only has one tab in the middle of the bottom and 5 holes around the fender. No holes in the tab for a bolt. The wood was missing when I bought the boat. Guess I will drill a hole in the one tab and do it that way. My trailer is pretty hammered as well.
    The Right Coast/SE-PA
    My 1983 21 Daytona sits on a 1983 Competitive trailer.
    The fenders are molded fiberglass that bolt to the trailer rails.
    The inner/boat side is a section of pressure treated plywood with foam padding and wrapped in heavy vinyl.
    Few years back I removed and rebuilt them, I can post pics if needed.
    Dallas, TX
    Thanks HD. My fenders are chrome. If you get a chance I would like to see pics. No hurry. Maybe it will give me some other ideas.
    This is how mine came, I like that they won't 'rust' and have steps built-in.
Name:	Trailer Rebunk 2.jpg
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    my 84 chrome fenders suck on mine. like 3 or 4 small bolt across the top is about all that holds them in. they are going to be done different.
    Mine had 1/4" plywood
    Swapped it out for a 3 layer thick
    Fiberglass panel and used button head
    Bolts under the carpet
    #55
    Pics or it didn't happen Paul...
    Should be pics on the build thread. Lol
    #55
    Such a showoff!!!
    How do you like having them vertical on your setup Paul? I like it much better than the way they're mounted on mine.
    That's the way they were
    Just changed to Fiberglas
    Actually building a new set since I gotta new wheels I had to move the fenders
    Out and up just a tad, now the old ones
    Don't fit
    #55
    Dallas, TX
    Outlaw that looks great. If I did mine that way I am pretty sure they would rub the back of the tires.
    Sleek, I like the idea of fiberglass fenders. Guess I need to look a little closer at mine before I decide how to proceed.
