454 getting hot!
Results 1 to 5 of 5
454 getting hot!
    Default 454 getting hot!
    I picked up a 78 Omega with a 454 and a Panther jet. I have had it out twice now and it runs great, but it seems to run a little hot (about 180) and the temp always climbs at idle. This weekend it started running around 210, so I shut it down and put it away.
    I traced the water line for a ball valve or a gate valve, but it goes direct from the pump to the block. I figured maybe a wear ring issue, but after searching the forums, it seems that Panthers don't use that technology to feed the motor??? Any suggestions? Thank you!
    Quote Originally Posted by mtrsportdan View Post
    It can be as simple as a piece of something stuck in the water line from the pump so first thing to do is start there and check all your water lines for blockage. Another not un-common problem is sand build up in the block.
    "I'm just SPRAYIN' man!!" '78 Crusader's Avatar
    Oct 2010
    McKinney, Texas
    I don't know anything about a Panther jet....just want to relay some information I've learned with my Berkley pump.
    I was having a similar issue with my BBF last year...the temp started to climb slowly until it was really hot... Come to find out, my pump thrust bearing was going out....and my pump needed to be rebuilt. While the boat was in the water, the impeller was pushing forward which blocked the cooling line to the engine. While on the hose it would never over heat but the moment I put it in the water, the temp would rise.
    I rebuilt my pump, put a new thrust bearing in and it's been running great ever since.
    Cliff
    1978 21' Crusader, 466 CID BBF, Berkely Jet
    1966 13' Boston Whaler sport, 40 HP Yamaha Two Smoker
    Before tearing into the pump I think I would be looking at water flow. Do you have a good flow of water coming out the dump when under way?
    Thank you for the replies.
    Not sure of any flow coming from dump. I have under transom headers, so not sure how to tell?
