hole shot problem in cvx23 glastron
Results 1 to 8 of 8
    Jul 2013
    Default hole shot problem in cvx23 glastron
    i have a 79 glastron cvx23 wth a 466 ported dv3 heads big roller cam and 850 speed demon carb
    having troulbes getting out of the hole acts like it wants to "cavitate" . i installed a loader that is supose to force water to the top side what else can i do to help solve this problem
    Shell Knob, MO
    Have you checked the condition of your wear ring and impeller? Could be loose and causing the slip. Also pretty heavy boat to move from a dead stop. The more power you add, the worse it could get. If everything is in good shape in the pump, I'd recommend a cavitation reducer impeller. They help those big boats a lot.
    Quote Originally Posted by drivenmarine View Post
    i have a 79 glastron cvx23 wth a 466 ported dv3 heads big roller cam and 850 speed demon carbhaving troulbes getting out of the hole acts like it wants to "cavitate" . i installed a loader that is supose to force water to the top side what else can i do to help solve this problem
    Big Boat To Get Moving. Probably Needs A Pump Rebuild By A Reputible Shop. I Would Also Add A Set Of Bennet Adjutible Trim Tabs. I Have Used Them On Jet Boats Over 20 Ft. With Great results
    A good pump is key, Those boats are heavy, and they get heavier with age When I have my 23 Sleek Jetboat, at a minimum tight pump with an A impeller. This was before the inducer was available in kit form, but impellers could be re-worked for better holes hot performance. As Duane mentioned, an inducer would help big time.
    Woodstock, IL.
    You mention no condition of the pump. Since DuaneHTP gave an answer give him a call. He knows a thing or two that could help you. I think his boat is about 23 ft. I can promise one thing, It's impressive to ride in.
    The government's monetary role is to maintain the integrity of the monetary unit, not participate in fraud
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    If the pump isn't up to it's potential, no matter what you throw at it (loader, horsepower) it will not help. Try going back to the stock rock grate and see what happens.
    Im non induced and My turd leaves pretty hard as she sits.
    Colorado Springs, Co.
    Make sure you're not sucking air anywhere, bad packing glands can suck air and cause lack of thrust.
    Are you sure the F/R bucket is fully opening?
    How does the front of the impeller look? If the leading edges are gouged, pitted, or flattened out it will reduce thrust.
    Are there by chance rocks/debris stuck in the bowl? Only takes 5min or so to pull the E pump bowl and check.
    Aren't the loaders supposed to help load the top of the pump at higher rpm/speeds? If so, it does you no good. I'd swap back to the standard rock grate as mentioned earlier.
    1978 Glastron/Carlson CV23; 429, Berk jet.
    Jan 2012
    St. Louis, MO
    My 2cts:
    - Get rid of the loader. It won't help that big boat much/any on the top end, and will make the pump cavitate on the holeshot.
    - As others mentioned, you probably need a pump rebuild and a new impeller. But check the packing to make sure it's not sucking air. Even if the clearances are "good", any cavitation "burn" marks on the existing impeller will only encourage cavitation. I went through this a couple of years ago on my 22' Dana with an AT-309 pump (9.25" impeller). Upgraded the horsepower just a bit (~50 HP) and I experienced holeshot cavitation that hadn't been there before.....
    Good luck
