460 oil priming problem
Results 1 to 14 of 15
    Jul 2013
    Default 460 oil priming problem
    just had a 460 rebuilt with all new bearings went to go prime it with a priming tool in a drill ccw and i first started with the filter cracked till it leaked out then tightened it up filled filter up but it never built pressure or came out of lifters or pushrods
    motor was just running and had good oil pressure before tear down everything was clean. reason i tore it down was to install a cam and heads and new hiflo dynamics oil pump. main bearins and rod bearings were plasti guaged and are in spec i did remove the frost plug on the back side of cam. when i reinstalled it did i possibly plug up an oil gally to the lifters?
    Senior Member motor head's Avatar
    Jan 2011
    It take a little time for it to get up there. You are spinning the pump counter clockwise right?
    [SIGPIC]
    Senior Member Quit Yer Bitchin's Avatar
    Jul 2010
    Quote Originally Posted by motor head View Post
    What he said. Distributor turns counter clockwise in BBF. Maybe a stuck relief valve in oil pump???
    California
    Quote Originally Posted by drivenmarine View Post
    Is it possible the gasket was left out between the pickup and the Oil Pump?
    Jul 2013
    yes i am turning it counter clockwise. i do have 5 psi after i repacked the pump with vasaline but no more than that and it wont go up the lifters so i took the pump apart and it looks like the relief is stuck open. i took an old pump apart and it was partially closed. the pump is brand new thru hi flo dynamics
    California
    You might want to talk with Paul before you take the pump to far apart. One of the mods he does gets the end of the relief out of the oil flow, at a glance it may look like its partially open but it shouldn't be open yet.
    Senior Member stc315's Avatar
    Yuma, AZ
    I seem to remember reading somewhere to have someone slowly rotate the crank while priming. Had something to do with position of the lifters in the bore keeping oil from going into the lifter.
    Too much horsepower is almost enough!!!
    My boat is fast.....on Craiglist or EBay.
    I've been 340mph+ with a boat........In the back of a C130!
    Jul 2013
    after doing some investigating my oil pick up tube is touching slightly to the pan after market pan and pick up tube which said they were capatable but guess not
    Senior Member johnf's Avatar
    Oct 2012
    When I bought my oil pump from Paul Kane Highflow He instructed me to make sure I had the right pickup to pan clearance! Suprizing he didn't mention it to you!
    Jul 2013
    what is the correct clearance i was told 1/4 inch to 1/8
    Oct 2012
    I bought a Armondo pan and set it at 3/8" plus whatever gasket width is. Working fine.
    3/8 " - 1/2" +/-
    1/8 is way to close
    Quote Originally Posted by johnf View Post
    I'd bet he did. I've got three pumps from Paul over the past couple of years..... he has told me each time.
    that would have to be one warped surface ..I've run pumps with and without the gasket.
