[Question] how to paint a boat?
Results 1 to 11 of 11
    Jul 2012
    Default how to paint a boat?
    hey every one I was wondering what the best way to paint a jet boat cheep but nice??? and how I should prep the boat...
    Racing
    Because Football,
    Baseball & Golf
    Only require
    One ball
    Senior Member uniboarder's Avatar
    Dec 2012
    Quote Originally Posted by 75' Anthony jet boat View Post
    Start with 40grit and work your way up to 2500grit!!!!
    Senior Member Sanger-Spectra's Avatar
    May 2010
    Do you want cheap or nice? you need to define your budget a little more and remember that fiberglass is not metal, so different process than painting a car.
    Dallas, TX
    Might look through the "Paint & Fiberglass" section.
    Senior Member Daniel Palin's Avatar
    Jul 2013
    Florence, MS
    Default Paint
    I have painted several. Tops & bottoms. The key to a successful paint job is in the prep work, i assuming you will be painting over the original gelcoat right? I always filled and light scratches with body filler or spot putty, then I always use epoxy sealer primer before I lay down any color. My preference on paint is Matrix brand Acrylic Urethane but to each his own on paint brands. Contrary to what some people may think, automotive paint works well on boats. Its not as hard or thick as gelcoat but as far as durability it does fine, just stay off the rocks, sandy beaches are fine. I will be repainting my 87 youngblood picklefork soon so you may want to follow me on here as I will post many pics as I go. Just remember to not cut corners and to take your time. I assume you are doing all the work yourself, if not.... Then you can get ready to pay a steep price if a shop does all the work. Hope this helps and good luck.
    Maple Ridge B.C. Canada
    there"s cheap , nice , & fast . you can only pick two !
    Jul 2012
    Lightbulb
    Quote Originally Posted by Daniel Palin View Post
    Thank u very much this will help a lot
    Racing
    Because Football,
    Baseball & Golf
    Only require
    One ball
    Senior Member dryhoze1's Avatar
    Sep 2009
    San Juan Capistrano / San Clemente, CA
    Quote Originally Posted by uniboarder View Post
    I first saw that and had to laugh, But oo"h so true !!
    Senior Member CampbellCarl's Avatar
    Whittier, CA & Katherine Landing
    Here's world famous Billy B boat/car painter at work.......................
    Originally Posted by Rattle Can Lou
    Again, if I came across as a v-drive snob..I apologize,
    Mike
    The Right Coast/SE-PA
    Quote Originally Posted by CampbellCarl View Post
    That's some pride of ownership right there.
    That should flow-out nicely!
    emf
    emf is offline
    Junior Member emf's Avatar
    Riverside
    Seen this done lots of times with gel coat ,let Hardin, color sand, buff , looks like new !
