Air actuated bucket question
Results 1 to 7 of 7
    Senior Member SlowRyd's Avatar
    Houston Tx.
    Default Air actuated bucket question
    Been looking all over the board and have yet to find my answer. Anyways what it the best yet cost effective valve to use to operate the air cylinder for an air actuated bucket and where do you get it?
    Placentia, CA
    Quote Originally Posted by SlowRyd View Post
    Are you looking for a switch or a Bimba valve?
    steveo143 AKA DiMarco 21 II
    Houston Tx.
    looking for a solenoid valve
    Senior Member wajetboy's Avatar
    Auburn, WA
    i have the part number somewhere, but i always just buy them from B1 racing, chris normally has them in stock
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Iuka, Mississippi 38852
    Heres a source, Contender Performance Products, Granville, Ohio. Phone 740-927-0060. PC750, 12 Volt 3 Way Air/CO2 Shut Off Valve, Maximun Pressure 125 PSI. Ports are 1/8" NPT. About $70.
    Jan 2012
    WW Grainger has them call me Ill give you the numbers or come by and you can look at what i use
    Bostick has done several of them. he should know
