Engine Mounting Question
Results 1 to 8 of 8
    Senior Member xxtremez's Avatar
    Jul 2013
    Texas
    Default Engine Mounting Question
    I am re rigging a TX 19 I recently bought. When I pulled the engine I found the stringer mounts were cracked for the engine mount. This is a 4 point Glenwood setup. The front mount appears to be straight and the rear dropped. Is this standard? If so what is the purpose for a rake on the engine mount.
    Thanks in advance.
    Fo Show
    Senior Member VAMI's Avatar
    srq,florida
    Chech the driveline angle.
    Jul 2013
    Texas
    What is an appropriate drive line angle?
    Fo Show
    srq,florida
    Imagine a line from the center of the crank to the center of the pump shaft.You want it straight .Sometimes there can be a very slight angle,few degrees in the hbar to make them quiet at idle.
    Jul 2013
    Texas
    Quote Originally Posted by VAMI View Post
    Thanks!
    Fo Show
    Atlanta, Texas, United States
    Quote Originally Posted by xxtremez View Post
    Generally on a stock Berkeley intake on a TX-19, the intake is installed at -4 degrees. Could be 5. You can check this by leveling or zeroing an inclinometer on the bottom of the boat, then place on side of pump intake (the part of the pump mounted in the boat that the suction housing bolt to) to see the exact angle of your boat. You want it reasonably straight with the crankshaft centerline, but if you have a driveline with two u-joints it does not have to be perfect.
    Redding, CA
    Ideally, the center lines should be parallel, but slightly offset.
    Usually the engine is slightly higher, or slightly lower than the pump.
    (But at the same angle)
    Just enough to put a couple degrees into the u-joint.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    X2 from 1/2-3 degrees in driveline but keep the crank and pump shaft parallel.
    Made In The Shade
    Custom Window Tinting
