Breaking in new Cam 460 Ford
Results 1 to 5 of 5
    Senior Member Quit Yer Bitchin's Avatar
    Jul 2010
    Default Breaking in new Cam 460 Ford
    I need some advice breaking in new cam and lifters in fresh rebuilt short block. Paper work that came with the motor says to add a bottle of zinc to the oil and change the oil after the first 2 hours. Add the second bottle of zinc after changing the oil and change oil again after 20hrs. Do I have to do a certain break in procedure for the cam? I remember having to run new engines at 2,000 RPM for 10 min or so to break in the cam.
    Senior Member jamesblown97's Avatar
    Mar 2011
    st george ut
    what kind of cam is it flat tappet, hyd. roller etc....
    Jul 2010
    Quote Originally Posted by jamesblown97 View Post
    Flat tappet
    Mar 2011
    st george ut
    when I had my motor built by a very reputable race motor builder we used a really good oil with the zinc additive and ran the boat at 2000-2500rpm for about 20 mins. he said for a tappet cam if you don't do it this way then the cam will go flat. after we ran it for the 20-30 mins we shut it down changed the oil and added another bottle of the zinc and went to the lake and ran it around the lake at 2500-3000 rpm for a few hours changed the oil again and since then ive been givin her hell and all is good. A good oil with high zinc levels is your friend in a flat tappet motor
    Already miss the 310/562 2manymustangs's Avatar
    My understanding of the procedure described above is that upon initial first run 30 +/- minutes you need to ensure that the came has as much oil/lube as possible thus the RPM of 2k - 3k...
    Not sure how available this oil is but it would be cheap insurance for the first few oil changes before switching to a full synthetic... I also dont know if doubling up on a zinc additive COMBINED with this oil is a good idea... At any rate this is a big issue and my engine builder/machinst buddy here in MO said that he lost MANY flat tappet cams when the oil mfgs removed the zinc and phosphorus from the conventional oils... Even lost some PREmaturely a while after break in... I for one wont build another flat tappet engine due to this, no matter the cost... In the long run a roller lifter set up is way cheaper than the cost and headache of loosing lobes on a cam...
    http://www.valvoline.com//products/c...ng-motor-oil/9
    Valvoline.com > FAQs > Motor Oil Car FAQs > Racing Oil
    Pat Eason, the voice of reason...
