Rpm fluctuation
Results 1 to 11 of 11
Rpm fluctuation
    Aug 2009
    Fox Valley Wisconsin
    Default Rpm fluctuation
    While crusin @ 3000 suddenly gain 200 rpm. Stays awhile then drops back. If I pull back throttle will reduce but will later drop 200 rpm. Feels and sounds good elsewhere. Wondering if it might be a intermittent plug wire problem. Any suggestions?
    Jan 2013
    Magic Mountain CA
    I'm pretty sure its not your plug wires. Maybe fuel system.
    Senior Member wpmxwb's Avatar
    Jan 2011
    Long Beach, California, United States
    What carb is on it?
    Aug 2009
    It has the same carb it's always had on it. It's a holley 750 with vacuum secondaries. At 3000 rpm I'm not close to the secondaries opening. This rpm changes sometimes happens @ other RPM's. I notice it most when just leisurely cruising. All off a sudden it will gain 200 rpm. If left alone it will usually drop back down within minutes. It will cycle like this over and over. If I pull back the throttle to original rpm it will later just drop back the 200 rpm. and I'll have to give it more throttle to regain the original rpm set.
    Senior Member SBS933's Avatar
    Jun 2012
    Replace your plugs, wires and cap and rotor. I had a plug problem in the past and I would lose 250 RPM per plug. It would start with one plug fouling out and then cleaning up, only to finally losing 2 plugs on a run. I went back to hotter plugs and problem solved.
    Believe Nothing you hear and 1/2 of what you see.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by 74Bonneville View Post
    Really? I just had this same problem last weekend on my little LS. I had burnt through 2 plug wires and didn't even notice. I replaced the wires and it fixed the problem.
    Damn LSs are pure magical.
    Yes they are Bob...... I really enjoy mine, but its bone stock.
    hummmmmmm sounds familiar: from years past
    two other wires were shot, but not as bad as that one. Engine didn't want to rev much at all ....
    That's what you get for not running a LS Jon. You could have redlined that thing for another couple outings before replacing it, and still kept it as a spare.
    them things are just a miracle engine ......... they could probably part the sea if you asked.
