pump bearing ?
Results 1 to 14 of 27
pump bearing ?
    sacramento
    Default pump bearing ?
    is it wrong to put the pump bearing in on a jg berkley with the notches in the race faceing toward the bowl verses the front splines, i was told it did & now i must pull motor, rideplate ,loader,remove whole pump .. i just did this last sat. night any info thanks, turbo wog.
    Quote Originally Posted by turbo wog View Post
    Actually the notch in the bearing must face the zerk fitting. That's where the grease enters the bearing.
    One part at a time... JohnnyNitrous's Avatar
    Surrey, BC, Canada
    X2
    notch goes toward the bowl facing zerk aligned at 12 oclock, that notch is there to allow the grease into the bearing. i always heat the bearing on the bearing heater and freeze the shaft makes installing the bearing much easier on the bearing,
    Ladera Ranch
    Why not just pull the pump out the rear of the boat?
    I'm thinkin' he has to do all that cause he has a 3 point mount setup.
    The notches (filling slots) are there to load more balls into the bearing during the bearing manufacturing process. The bearing type is a max-type double row angular contact with a back to back internal design, and if the notches are positioned in the wrong direction, then under thrust or axial loading, the balls can traverse the filling slots and degrade the bearing. Since the thrust direction in a jet is predominately forward, the notches should be towards the engine because the rear row in the bearing will carry the thrust load.
    If anyone can provide actual thrust load numbers in pounds or newtons I can have one our apps engineers (I work for NSK) determine if a max-type bearing is even needed for a jet application. If a max-type (extra balls) is not needed then a standard double row can be used and the notch location is not a concern because the standard bearing does not have a notch.
    This topic was covered on a HB thread or two and may still be there.
    Monroe, WA
    What SoCal said. A bearing doesn't need big slots to take grease!
    Malcolm
    75 Spectra 18
    77 Spectra 19 project
    sacramento
    can't get to the last bolt on bottom , double drilled
    sacramento
    yeh 3 point & twin turbo crap with water lines etc.
    sacramento
    Quote Originally Posted by SoCal View Post
    thank you, i did pull it & flipped the bearing . dropping motor back in tomarrow. thanks everybody!!
    B1 Racing cs19's Avatar
    what so cal said is right on the money.
    moral to the story dont believe everything you read on the internet or the Seloc manual either.
    B1Racing.net
    MI
    There are two types of thrust bearing's. On one the notch faces forward and on the other it faces the rear.
    Ladera Ranch
    Good time for a rail kit!
