Need Help
Results 1 to 14 of 14
Need Help
    Junior Member tunnelmann's Avatar
    Whittier CA
    Default Need Help
    I picked this little jet boat up for the wife It has a Nissan 4 cyl in it
    Had a cracked head so I replaced it First time out & it won't get up on plane motors taching 6 grand I pulled the back half of pump off & the impellar is perfect not a nick in it Anyone have any ideas what could be wrong with it????
    Hondo Jet blown540's Avatar
    Holland, Mi
    Wow, that's a head scratcher. It's either cavitating due to a restricted intake or there is somthin funky going on with the powertrain. Is there a key in the impeller? I don't know what's in between the motor and the impeller but I would be finding out. Good luck
    Q.C./Big River
    Quote Originally Posted by tunnelmann View Post
    Check the packing in the pump, if you are sucking air then you won't go anywhere, lube it up and tighten the packings a turn or so and that might help.
    Or you might have something stuck in the pump. Also the pump could just be in need of a rebuild as well.
    Whittier CA
    Where is the packlng? I don't know sh!t about jet pumps but it felt to me like it was cavitating/sucking air
    Ladera Ranch
    does the boat move at all?
    Olympia, Washington
    Get under the back of the boat and look up into the intake of the pump is there anything stuck up in there?
    Whittier CA
    Quote Originally Posted by Oldelmn8tr View Post
    I said I don't know sh!t about jet pumps But I'm not frikin stupid
    & yes it moves just won't get on plane
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    any pics of the rear or anything other than the front in the driveway?...looks like it would be fun to goof around with!
    P.S. dont take any sort of offence to that!
    Whittier CA
    Quote Originally Posted by toddnjuzz View Post
    TRG
    TRG is offline
    I would be waaay interested in seeing the inside of that Doen pump, does the thrust line seem a bit high to anyone else??
    Owner/Crew Chief 1/4 Miler's Avatar
    Rural Missouri
    Just a guess, but, looks like too much weight too far back combined with too little thrust being generated by that small DOEN Pump ... a much longer, lighter weight ride plate might help some, but, don't expect too much due to the weights & balances with that small pump (lack of thrust proportional to the CG). You may never be able to 'get it up on plane' due to what it is and may have to settle with just a 'putt around' ..... which isn't a bad thing and has its use.
    Something you might want to try to increase the thrust 'a bit' is to put a restriction in the nozzle to decrease its size a little ... going to be difficult requiring 'one off' piece(s) as those old DOEN Pumps are not set up for nozzle inserts.
    New Jersey
    The boat appears to be a production piece and not a one off piece, so I would believe that it should at least get up on plane in new condition.
    We have eliminated the simple stuff, blocked intake etc.
    Next need to ensure that the driveline is in proper working order - no slipping coupler, all drive keys in place. What sort of coupler does this pump use? If a u-joint driveline like Berkeley, nothing to slip, if a rubber coupler like an I/O then that could be a problem.
    From what little I could find on the internet, the Doen pump is an axial flow pump (like Jacuzzi YJ). I would be looking to verify the clearance between the impellor and housing is withing spec. What is spec? I would guess around .015", but don't really know.
    Doug
    I never hit bottom. 79Challenger's Avatar
    I don't have any input on your problem but I just wanted to say, "Cool boat!"
