Help needed.
Results 1 to 7 of 7
Help needed.
    Tacoma Wa
    Default Help needed.
    I am in the need of a foam BBC or a junk short block with crank in so I can jig up my rail kit and set drive line angle while my engine is in the machine shop. Im willing to pay rent for a foam block, or if you need disposal of the junk short block I'd be happy to do that too.
    I am located in Southern Ca, Rialto to be exact. THANKS!
    ~Brian
    Tacoma Wa
    Guess I'll post this up in dock side to see if I get more coverage.
    Glendale Arizona
    If you were closer and needed a BBF bare block I could've helped you out.
    Brian find a smokin deal on a "mock" Block and let me know,maybe share $$ ??
    El Cajon, CA.
    I have a block but I want to keep it. I can loan the block out but I want it back. I don't have a spare crankshaft.
    RAT PATROL rich s's Avatar
    S central Pa.
    Default mock up block
    here is a block with a tiny crack
    it ran just fine but would let moisture condense in the valve
    cover,
    too bad i `m on the right coast
    454 plus .125 and 1 sleve in #4
    Tacoma Wa
    http://www.pitstopusa.com/detail.aspx?ID=69148 400 bux
    http://store.summitracing.com/partde...5&autoview=sku and summit has one too.
