Impeller Advice
Results 1 to 6 of 6
Impeller Advice
    Member 1980condor460's Avatar
    Newcastle
    Default Impeller Advice
    Southwind tunnel. R intake, shoe, loader and ride plate - Berk pump - aggressor split bowl - droop snoot and diverter.
    Engine makes @600hp at 5800 RPM's and 622 ft. Lbs at 4800 RPM's.
    Thanks for the help.
    Atlanta, Texas, United States
    Quote Originally Posted by 1980condor460 View Post
    Are your numbers from dyno testing? If so, are the corrected or uncorrected numbers? If they are corrected, I think I would try a "B" impeller. If uncorrected possible an A/B.
    Uncorrected 600 HP should turn an "A" impeller about 5500 and a "B" impeller 5800. If these are corrected numbers and you have a good pump, you can subtract about 100 - 150 RPM.
    Newcastle
    Corrected and I was also thinking a B would be a good place to start. Aluminum, stainless or bronze? Not sure what the hp ratings are for each.
    Mar 2010
    Clarksville, TN
    JMO, but I would start with a A(bronze or Stainless) and trim from there . You can always take material off but can't add !!!!
    Shell Knob, MO
    I would start with an A/B Stainless Steel. AMT or Dominator Impeller.
    B1 Racing cs19's Avatar
    B or B+ depending on wether its being blueprinted. I like the AMT SS impellers the best myself
    B1Racing.net
