[Question] Where is best place for P/D handle?
Results 1 to 14 of 17
    Senior Member johnf's Avatar
    Oct 2012
    Default Where is best place for P/D handle?
    I'm wondering where to put manual P/D handle for ease of use and keep it out of way? Never had one before Laying out seats and throttle want to put some backing for handle before carpet. Also see how to run the cable to the back. Any input is greatly appriciated! Johnf
Name:	seats 001 (1280x960).jpg
ID:	344257   Click image for larger version.
Name:	seats 002 (1280x960).jpg
  2. #2
    ATM
    ATM is offline
    Amerian Turbine Man
    Clarkston, WA.
    Quote Originally Posted by johnf View Post
    PM sent
    One less DEALER means more DISCOUNT for you
  3. #3
    I dropped mine into the floor...its a stringer mount. Ran cable inside along stringer with throttle. last pic cables on alt side.
    Made In The Shade
    Custom Window Tinting
  4. #4
    Jan 2013
    Magic Mountain CA
    I put mine next to my seat where my right arm hangs. This is comfortable for me.
    Some mount right in front of seat between your legs.
    Sit in your seat and place it. See what feels most comfortable to you.
  5. #5
    Similar to what Jeff 74B said and assuming you have a floor mount style , just right of your drivers seat and at a slight angle (front of the controller) , sit in the seat and put your controller on the floor to see where its comfortable and easy to shift full range up and down where you can keep your eyes focused directly ahead
  6. #6
    Renegade jet tunneljet's Avatar
    Shorewood Il
    Having had a manual handle and switching to hydraulic I would say ditch the lever all together! The hydraulic is much nicer and a cleaner look. No big handle in the way.
  7. #7
    Quote Originally Posted by tunneljet View Post
    Its like driving an automatic hot rod and do you have a thumb throttle going in as well.... Manual is somewhat nostalgic for a 70-80's jet.
    Made In The Shade
  8. #8
    Jan 2013
    Magic Mountain CA
    My Cobra came with the hydraulic style and I like it on this boat. If this is where you want to spend your money the next time your ready to Break Out Another Thousand then by all means go for it. It will give you the ability to set it anywhere instead of the notches in the manual style. Most of us don't notice the difference, if your racing for the lowest ET then it will make a difference.
  9. #9
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    Manual- Handle and cable
    or
    Hydro/electric- switch, relays, wiring, hoses, connectors, hydro ram, hydro fluid IN boat, pump, etc.
    I like simple. I like manual. My handle is next to my seat. Same place a floor shifter is in a street machine!
  10. #10
    Shell Knob, MO
    I like them mounted right in front of the drivers seat. Mount it to where the lever is about 1" from your seat cushion when the lever is in the back slot. This makes it easy to use without ever getting out of position or even having to look what you are doing. It never gets in the way there because it is an unused area; Unlike out on the floor where it gets in the way of feet, coolers, skies, etc. On some of the tunnels where the lever gets a little too close to the steering wheel, I cut a 1" piece out of the handle, weld it back together and polish it. On a flat floor, it's a no brainer. When they have stringers, I build an L Bracket out of angle aluminum and still use the floor mount control. To each his own. Just my idea.
  11. #11
    Aug 2010
    does anyone ever use a 2nd pedal with an override similar to what the vdrive guys use for cav plates?
  12. #12
    Quote Originally Posted by ka0tyk View Post
    The left pedal in Joshes little boat is an override for the Diverter
  13. #13
    Shorewood Il
    You are right, it is safer having both hands on the wheel. Like I said after having both styles I would never have a handle! Plus I just don't like the cluttered look with a bunch of crap mounted all over. A gas pedal, steering wheel, and shifter. Nice and clean!
  14. #14
    83 Crusader - 468 BBC SNiC's Avatar
    Apr 2011
    Sweet Home Alabama
    AND....I always know the exact position of my diverter
