help it cam selection
    Aug 2013
    Default help it cam selection
    so I am building a 454 for my 21 foot hawiian mini day cruiser my motor so far is a 73 block bored to.060, 049 heads haven't done the cc yet (waiting on the kit to get here) but I think they are 115cc, 20cc domed speed pro pistons which should net me around 9.5-10:1 compression(wont know till I cc the heads and get the pistons in the block to see how far down in the bore they are at top dead center), .020 mains and rods with king bearings and for now I have a edelbrock performer 2.0 intake and a 800cfm holley double pumper...... I have an isky 280 mega cam but the problem is they told me I didn't need springs and im finding out I do as well as, tell me if im wrong but hardened push rods and the valve guides getting machined down.... if this cam is really worth all the hassle I will do it but if there is something you guys think would work better with my set up or comparable with out all the hassel let me know thank you in advance a 73 but i thin b, an
    Nov 2009
    Jet? Exhaust? Thru transom or over? Intended use? And valve size in 049 s ??? I would keep it below 10 to 1 if you plan on running pump gas. These are the questions cam company's need, and FYI 049 heads are typically 119 cc unless they have been milled.
    Aug 2013
    sorry yes it is a jet with an a-2 impeller and im running logs with over transom. I have read people saying many different cc sizes for the 049 that's why I am saying I know I will be somewere in the 9:1 - 10:1 range the max should be 9.9:1 and I gave isky all that info and they sent me the 280 mega but im wouldering what u guys think of that and if it is really worth all the extra money and hassle to put it into my setup cause it looks like I will have to machine the valve guides and install hardened push rods and heavier valve springs
    Shell Knob, MO
    That's a good cam.
