Aluminum Heads?
Results 1 to 14 of 59
Aluminum Heads?
    Member UrbanLegend's Avatar
    Default Aluminum Heads?
    I have a 460 and I currently have steel heads and I'm thinking of changing them out for aluminum heads. Has anyone here ever had any warping problems with them (berkley jet)? Also, can some give me the pro's and con's to changing them out? I have a 23' footer and I'm not going to be out racing or anything, but I would like to add more horsepower for added weight to my boat. Obvioulsy aluminum or steel isn't going to make that difference, but will there be any real difference in the weight of the motor?
    Thanks for any and all input.
    Quote Originally Posted by UrbanLegend View Post
    Get the Blue thunder heads, other wise it's a step sideways. The BT heads also allow for chevy exhaust systems to be used, much more readily available.
    You may want to try a thread search over in the dyno area, The topic has come up quite a bit. Alum. advantages are obviously weight and repairability. I think if cc's and all else were equal. The iron heads will make slightly more power than their tin can brothas.
    Senior Member CK7684's Avatar
    Minnesota
    I've been running aluminum heads on my BBC this season with no problems...get studs instead of bolts to hold 'em for better clamping force distribution...I also use a thermostat and water pressure regulator. Also keep in mind that alum heads will soak up heat more, so it's like dropping a full compression ratio point...
    I think not. or that small advantage if it does exist is over run by the other benefits of the alumi heads.
    Savings of at least 80lbs of the back of the boat.
    Sleeper CP
    Big Inch Ford Lover
    Thank you men, very much appreciated. I'm sorry to tell you that you're talking to a (pretty much) illiterate when it comes to tech talk. I'm trying to learn as I go.
    The cooling issue is one of reletive ease isn't it? As long as everything is cooled properly, I really shouldn't have much to worry about, right?
    Thanks again.
    Santa Clarita
    I wouldn't waste your money on a set of Aluminum heads for that 23' boat. It's a big heavy boat and your money would be better spent on some head work on the steel heads you already have, or a stroker kit, or something else. What you are looking to get isn't worth going the extra step for aluminum heads. Just my opinion. If it was a smaller performance boat then I would say go for it.
    Do you think it would be worth the weight loss to the back of the boat?
    Thanks again.
    Operating rpm range ?
    The port shape of a modern Alumi head, even under 5,000 rpms will gain you power over cast iron heads, Blue Thunders or even Edelbrocks come to mind.
    Even though you have a heavy boat 80 lbs is 80 lbs. Even if you stick with porting your stockers use a RPM Air Gap intake and a good cam swap and you can add 50-75 hp to your 460 under 5,000 maybe even more. I wouldn't do the head work without a cam swap your effort will be diminished.
    Sleeper CP
    Do you know what heads you have now? If the alum. heads had smaller chambers then you might make more power. If they are too much smaller you may have pump gas or other issues. I wouldn't spend the money just thinking alum. heads will be faster. Unless maybe you have some crappy heads now . peanut ports or something.
    Senior Member djmadmatt's Avatar
    Erie, PA
    Santa Clarita
    No...in a boat that big you will never see or feel the difference. Your money is better spent somewhere else.
    Thank you for the input.
    I'm just thinking if I lighten up the heads I could get a 320 pound hottie in the back instead of just a 240 pound hottie.....
    My 23ft Sleekcraft Executive would hit 70 no problem, with a 540 BBC on a mild cam. 5400 rpm's turning an AMT AA impeller. Weight has some effect on top end, but more of an effect on acceleration, than anything.
