scoop tray hold down bracket
Results 1 to 14 of 17
    Senior Member steadymobbin's Avatar
    Apr 2010
    Default scoop tray hold down bracket
    Anyone have any trick ways to hold a scoop tray down for dual carbs? Trying to come up with something that doesn't impede air flow and I'm stuck in a rut.
    Mar 2010
    Clarksville, TN
    Jegs sells a real nice one
    Flying Yanez Racing Crusader Kid's Avatar
    Ramona, California, United States
    My friend designed this one for me
    I'm not here for a long time. I'm here for a good time!
    Senior Member LOLYFE's Avatar
    Idaho
    I made a bunch extra of these, billet aluminum for 4150 or 4500, work well with dooley type scoops, and others, they have a wide "feet" for surface area to help hold scoop base securely , pm me for details, Tim
    Tempe/Big River
ID:	346089 bolt it to the valve covers u can hide ur trick carbs!
    Senior Member BingerFang's Avatar
    Jul 2012
    Quote Originally Posted by white tortilla View Post
    Ahahahahha 😂😂
    Quote Originally Posted by LOLYFE View Post
    Those look trick, PM sent Tim.
    Senior Member Nailhead's Avatar
    Castaic Ca.
    Hollow rods with quick release ends
    on 3 go..... Slow Burn's Avatar
    Aha - SoCal.
    Jeg's or Summitt. Simple & clean. Solid mount with NO airflow restrictions. Dual carb set up has identical concept.
ID:	346361 2008, 555ci
    Senior Member ontheNOS's Avatar
    Jan 2012
    Inland Empire
    This is what I use. Works good. Super clean and there 69.99 each from jegs
    Hope this helps
    Tim this is what I'm dealing with, I hold down my tray with my flame arrestors at the moment, I would love to eliminate the arrestors if these will work? Carbs, tray, arrestors, scoop, like I need to explain that. LOL
Name:	Flame arrestor.jpg
ID:	346881   Click image for larger version.
Name:	Intake no tray.jpg
    Oct 2011
    Sandia,Tx. 78383
    I used 1/4" x 2" aluminium stock bent ears down about 2" above carb and drilled hole in center for bolt holdown But them ones up yonder sure looks purty !!
    http://oathkeepers.org
    Idaho
    Here is a pic of how I use them, aluminum scoop pan was punched with correct inlet radius for carbs and broke to fit inside scoop, dzus buttons hold it to tray. Bent a 1/2 inch piece stainless tubing that front of scoop tray bolts to then goes to front of block.top part of bracket is attached with captive nuts welded to bottom of scoop bracket. Entire scoop/pan assembly comes off in less than 30 seconds, may not work for everyone but works for me.
    Senior Member bc18's Avatar
    Quote Originally Posted by Gopher711 View Post
    Same thing I did. Bent them in a vise.
