Finally hit the water!
Results 1 to 6 of 6
    Default Finally hit the water!
    Gentlemen, finally had some time to take the ole 16' Tahiti out to Saguaro last friday. First time out since ihave kindof learned what i'm talking about in the jet boating world. Ran real good, at 4500 rpm was doing 48 mph on the handheld GPS, so it's not to bad. Didnt want to rev the 455 any higher till i do the oil modifications. I imagine after i rebuild the pump i will pick up some MPH.the leading edges on the impellar are pretty chewed up and i can feel some radial movement on the shaft so i'm sure the tail bearing has seen beter days along with the wear ring. All charging system issues are taken care of thanks again to all the people who put their .02 in. how much mph do yall think i will gain with a fresh pump?
    Senior Member CK7684's Avatar
    Minnesota
    Nice!! Another 16 footer Love to see some pics...I'm running 66 (GPS)at 4800 rpm with a fresh overhaul on my pump, but my (A size) impeller is a bit nicked up, so it's not absolutely perfect. I've also got an Ultimate Wear Ring from HTP...best I've seen is 5300 RPM but I didnt have a GPS then...
    Not much to look at yet but it'll work. I also have an A size impellar so maybe upper 50's to lower 60's would be a number to shoot for. Like to see some pics of your ride too.
ID:	17754   Click image for larger version.
    SLOW MEMBER slowboy's Avatar
    Duluth, MN
    Quote Originally Posted by 16' tahiti View Post
    What do you mean not much to look at? Looks good to me
    92 KURTIS RUNNER BOTTOM
    Quote Originally Posted by slowboy View Post
    he can beat you to Germ
    A ARMED SOCIETY MAKES FOR A MORE CIVIL SOCIETY
    Thx slowboy! i'm just not to much of a fan for the green.
