Ok guys,
I know this topic is a little redundant and for that I apologize. After a great weekend in Laughlin/Mohave I decided to take one more run from Davis dam down to Harrahs and back several times. Always fun to make a few early morning speed runs to make sure the folks at the Davis campground aren't sleeping to late. The unfortunate part is when I was putting the boat back on the trailer I noticed some milkshake coming out of the breather and around the dipstick. Upon pulling the valve covers I discovered more milkshake. I'm running a BBF 472 OT headers Berk pump in my 18' Dimarco. I'm running the gate valve basset tee setup. I know some of you guys are going to suggest the Ford is my biggest problem but cut me some slack I just milked my motor. Boat ran great oil pressure good temp good plugs all look good. There was absolutely no indication of a problem other then the milkshake. Inside of valve cover were thoroughly coated with white milky shit not so much however on the dipstick,some evidence of water just not the white stuff. I'm familiar with the Ford timing cover issue as I had to replace it once and it seemed to take care of problem. The boat had been garaged for 5 years prior to this trip so maybe a gasket issue? Thing is everything was fine until that last hour long river run. Anyway totally bummed so I'm trying to get a punch list together so I can start digging in to diagnose and fix. Thanks
Sent from my iPad
Looks like condensation from running it hard and going straight on the trailer, that is if its not showing milkshake in the pan.... if the oil level hasn't raised at all, run it on the hose and check the oil while its running and see if it shows milkyness on the dipstick or more water appears in the oil pan.
OK, I am new to all this boat stuff and only here to learn all I can, so please explain something to me about this condensation thing. So please bear with me.
The OP said he made more than one bonsai speed run from the damn to Harrah's. Lets give the OP the benefit of running his oil hot enough to burn off moisture while its being hammered. Maybe 180-200 should burn off any small traces of moisture in the oil given the time it takes to make those runs.
Now he shuts off the engine and BAMB, the moisture of the humid ass desert summer rushes into his cooling engine.
NOW HOW DOES IT ALL GET MIXED INTO HIS OIL WHEN THE ENGINE IS SHUT OFF??
I am worried, because my engine see very similar use. Very little low speed running. Pretty much balls out and shut off. I am concerned this could be happening to me. Never seen it, but then I haven't had the valve covers off in 10 years.
I've experienced the milkshake on more than one occasion. Several possibilities. Had water come through the exhaust when I had logs once. You probably didn't hurt the motor, but you do need to go through the process to remove the milkshake and start over. I was taught by an old school guy the first time I did this to change the oil & filter substituting 1 quart of oil with 1 quart of diesel fuel. Run for 2 minutes, change oil & filter again. Run it to get it to temp. Then the process of finding the issue. Is it something simple like the exhaust or is it a internal gasket or ???
Compression check, leak down test, .....
I had the milkyness under my valve covers with my OT headers until I installed a on/off valve next to my seat for the exhaust. When at idle water to exhaust is off, then I adjust when I'm running always shutting it off to dry out exhaust before shutting engine down.
If I put ball valves at the inlet of each of the header water supply lines and shut them off befor shut down will it do the same as the under seat mount valve? Without filling up the motor?
I would plug your water in and out fittings except one, hook up a radiator tester or similar, pump air into the system, say 5 lbs or so and see if it holds. If not, start testing separate components like each exhaust manifold, etc. Use soapy water to find leak(s) outside engine such as the intake manifold.
Oh, and this is flat hilarious by GN7 "OK, I am new to all this boat stuff and only here to learn all I can"
WTF, Beer 30 posted in another forum that I FINALLY got one post right. Oil related too! I am ecstatic! artyguy:arty-smiley-020:arty-smiley-020:artyguy:
If I had a engine that sat for 5 years and was taken out and ran great all weekend, and when I got home it had a little milkshake in it I would call that a win!!!!!! Change oil and filter,shut water off to headers till ranger stops you and run it until something really goes wrong. JMO from a real novice boater!!!!
My gut instinct would be to look at sealing areas where water pressure could push out a gasket and pump water into the crankcase. If this motor sat for 5 years, it would make sense that a seal or 2 got rock hard. Then you go out run it pretty hard. After a couple of heat cycles and water pressure building up against sealing areas, some place lets go. It would only take a very small leak to milk the oil. Also, even though this boat has probably lived in a fresh water environment, don't underestimate the corrosive capabilities of the Colorado river water. It could have eaten up some of the cast aluminum parts again(intake or timing cover). I would be pressure testing the cooling system.
And Mr.Gn, if you read carefully, act respectful, and keep quiet, you might just learn a thing or 2 from some of these guy's around here. :shhh:
It would not be during, Definately after would be my guess and I wouldn't think his engine builds the kind of heat yours does being naturally aspirated to remove moisture out the same. I could be very wrong making that assumption but if there were no signs of water anywhere else that would be my guess.
Then MAYBE it should be. Heat in the engine is water flow verses HP. maybe he shouldn't flowing the same amount of water thru the engine I am if he is not making the same HP. Ya think?
My water exit is around 140*, my oil temp is around 250*+. Is his? Has he checked?
Directly copied from the Post -->>"There was absolutely no indication of a problem other then the milkshake. Inside of valve cover were thoroughly coated with white milky shit not so much however on the dipstick".......... I love how someone asks for help or info on here and people feel the need to comment negatively when all most people on here are trying to do is help even if the info is minimal..... Some of you guys crack me up. But I am the DIPSTICK? hmmm
Thanks I really appreciate any and all info given the fact that you guys are taking the time out of your day to help me brainstorm this means a lot Thanks
Ok guys,
Sent from my iPad
Change out the oil with cheap oil and filter run it a short time on the trailer , change it again with your brand of choice , take it out and get the oil warm drive it some more and see if the issue ever repeats.. BTW what Valve covers and what brand/type breathers ...
Ok guys,
Sent from my iPad
This is what I read not that it really matters hand yes as I read below I see the change
Oh well:knockout:
Related Threads
Performance Boats Forum
2.1M posts
41.1K members
Since 2007
