loaders
Results 1 to 14 of 61
loaders
    talks cheap! oilfieldtrash's Avatar
    farmington
    Default loaders
    what kind of gain should be expected by adding a loader? bottom end ,mid range or top end? i am going to try one this weekend that a friend is loaning me to try out. i will post a pic of it tomarrow.
    Quote Originally Posted by oilfieldtrash View Post
    The loader works in relation to the bottom of the boat and can make MPH and can build bottom end. That all depends on how the loader works with the bottom and the motor. If you want to post pics then do it with the loader in the boat from the front looking back as close to the bottom of the boat as possible and then from the back looking forward. A loader with to much bite will drop rpm and make the bottom end of the boat better. Aloader with minimal bite will raise rpm and help on the top end. This a drastic statement but it's bottom line. Fine tuning a loader to the bottom is an art and takes time on the water. Off the shelf loaders are a general starting point. Mark
    farmington
    thanks olguy i will post pis tomarrow and will run it this weekend. right know all i have is a rock grate. i turn a A impeler 4600 rpm @6200 ft above sea level on the bottle i turn it to 5100 rpm give or take the day water and air. just for info i am running a 78 nordic bubble deck with a mild 461bbc and a worn berk 12jc pump
    thanks for the info
    thanks for the info
    If the boat leaves hard and doesn't blow a whole in the water on take off the pump sounds fairly solid. From the rpm you are stating, sounds pretty good. FYI the early jc pumps flowed 72 gph and the newer stuff flowed 68 gph. Good luck this weekend!!! M
    farmington
    it blows the pump out if i leave hard i have to feather the throttle a bit once it bits it runns pretty hard
    Question
    How do you know if you have an early pump or a newer pump? Can you tell by looking at the serial # on the top of the pump?
    Thanks.
    Jet numbers## would be helpfull ,post them up ! Tom
    I just went out and looked at the tag and the Serial# is 7558948. And the BM# is 6470. And it is stamped as a Model 12JC-A. But I had an AB impeller installed a few years ago.
    Thanks.
    Small Pumps flow more then that.
    a stock bbc fuel pump will pump that
    Opps sorry I got my minutes and hours mixed up!!!! M
    I do not know your HP - Less HP more Blocker as HP go up the blocker is opened up. (On Ramped Loaders) Ski- River Loaders have just 2 angle ramps comming down work great unless you start getting in Bigger HP. Good Luck!
    lol, i know, jus messin
    Here are a few examples :
    http://home.pacbell.net/jmcclure/Loaders.html
    Sleeper CP
    Big Inch Ford Lover
