[Question] Who has trim plates cavitation plates on their jet?
Results 1 to 14 of 19
    Senior Member HotRodJosh's Avatar
    Oct 2010
    Spanaway, Washington
    Default Who has trim plates cavitation plates on their jet?
    Im looking for pics of trim tabs on jets....as I need to make some for my boat. Close up of hardware would be great, as would sources for the turnbuckles, hinge, etc.
    My freshly finished boat has a bad porpoise and from all the researching here, trim plates may be the answer.
    Thanks for any help!
  2. #2
    Rancho Cordova. CA
    If you don't have a place diverter, you should start with that first!!
  3. #3
    Close to the water...
    Quote Originally Posted by HotRodJosh View Post
    Here you go the fastest CJ in the Kilos
  4. #4
    Oct 2010
    Quote Originally Posted by carreradude View Post
    Got one. .makes no real difference over 50....I know the problem....just wanna see others tabs to see most economical way of fabbing some upm
  5. #5
    Senior Member 76 Hondo's Avatar
    Aug 2010
    Mission Viejo/Lost Lake
    Here's my Hondo cavitation plate set-up,
ID:	350610   Click image for larger version.
ID:	350618   Click image for larger version.
  6. #6
    Member CashLeak's Avatar
    May 2013
    Default Hydrolic Trm Tabs
    My Nordic had them on it when I bought it. They must have come off a 40' cabin cruiser if you have them too far down at take off they force the bow of the boat hard into the water . Best to keep them up a bit out of the hole
  7. #7
    Senior Member almost busted's Avatar
    Sep 2012
    MN
    dam!!! 76 hondo thats one sweet ride you have !!! looks killer
  8. #8
    MADSKILLZ cj222's Avatar
    West Covina
    Here is the setup on our Rogers
  9. #9
    Nov 2009
    Quote Originally Posted by cj222 View Post
    H.B
  10. #10
    Oct 2010
    Nice setups so far guys....say what are yall using for hinges? And what material are plates themselves? Ill be making my own....
  11. #11
    Aug 2010
    No hinges, just aluminum plates you shouldn't need a lot of down peddle just the flex in the plates, moves maybe 1/2".
  12. #12
    Oct 2010
    Ok...so it appears yours bolt onto the bottom as opposed yo the transom then? How thick is the aluminum and its grade? Scrap aluminum and SS is readily available to me.
  13. #13
    Heres some made by my son Josh to help control the porpoise on my previous boat
  14. #14
    Silverdale, Washington
    Josh, while these are on a pedal, you could easily copy them and make them solid without the pedal for your boat. Plus, you can come and take measurements and pictures anytime you want since it's close to you. .........john
    [/QUOTE]
