Rules to race the my boat lucas race
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 46
    Senior Member AJDEAN955's Avatar
    Aug 2011
    L.A.
    Default Rules to race the my boat lucas race
    Want to run my boat need to know what they look for when they tech a boat at lucas?
    What do i need in my boat and safety equipment wise. I have a new chute jacket and neck restraint deal to mount to my helmet and getting the ballistic shorts what else do i need?
    JUST A KID IN THIS OLD MANS WORLD......
    Anza Valley, Lost Lake, CA
    Quote Originally Posted by AJDEAN955 View Post
    Say you don't go over 100. Will need all PPE, dot physical, rope deflector, battery shut off, kill switch, throttle stop and numbers on boat and tow vehicle.
    Aug 2011
    L.A.
    All PPE as in? And ok cool only thing I need is rope deflector and battery shut off on the boat and does it matter how far it is from the battery or would right next to the battery work? And what of iam over a 100 mph?
    Senior Member bp298's Avatar
    LHC
    really depends on how fast the boat is and the class you'll enter. curt gave you the general idea. but, for example, for ME and slower, you don't need a dot physical. for TE and higher, you will need the physical and also apply for a license. there can also be some additional boat requirements depending based on class.
    http://www.lucasoildragboats.com/pdf...ok_Revised.pdf
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Over 100 u need a jet away or pop off. I herd somewhere you're suppose to have grade 8 loader bolts???? I am working on the Same thing AJ
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    Should be certified Lifeline, helmet restraint, snell approved helmet, ballistic shorts, t-shirt, long pants, vans, and last time they wanted it inside at the back of the boat. Jet away or pop off.
    Quote Originally Posted by jyeager View Post
    Well yeah and they should be drilled and tapped through with self locking nuts.
    Aug 2011
    L.A.
    Ok should dialed on all the PPE now just to get a battery switch I should be dialed what class are u going to run jake?
    Aug 2011
    L.A.
    Ill had to figure a way to slow the boat down if I can't run over a hundred...
    First time you'll be fine at ONE OH something.
    Aug 2011
    L.A.
    Right on sounds good
    Senior Member Racer J's Avatar
    Visalia CA
    What race are you shooting for?
    Throttle return springs on each carb and drive shaft cover or loop.
    Mar 2010
    Clarksville, TN
    Best thing to do is crew with sum guys for a race and get a fill of what's goin on..
