Need a little wiring advice...
Results 1 to 14 of 16
    El Cajon, Ca.
    Default Need a little wiring advice...
    Where should I put a splice?
ID:	353602   Click image for larger version.
    The Bostick®
    Senior Member Racer J's Avatar
    Visalia CA
    Looks like there's room for at least one more, maybe two if you get creative!!
    All you need is the red, white, and black one.....
    Jan 2013
    Magic Mountain CA
    That's Awesome
    Pretty sweet job I must say. So how much does a "custom" wiring job go for these days?
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    Spaghetti dinner for you tonight James!!!
    Senior Member SBS933's Avatar
    Jun 2012
    PM Sent
    Believe Nothing you hear and 1/2 of what you see.
    Residential type wire nuts sealed with black tape wraps will be your friend ....
    Senior Member GottaJet's Avatar
    Santa Clarita,CA
    Shhh!! Can you hear that?? GJ
    Senior Member johnf's Avatar
    Oct 2012
    WOW Never new those EFI setups were that clean!!!
    El Cajon, Ca.
    Nope... white, black, and green... don't need red... we ain't dealin' with 220v.
    I actually worked on a buggy one time that every single goddamn wire in the whole thing from tip to tail was purple... power, grounds, senders, every fucking wire #14ga purple. After 2 days of trying to wire in an msd and trying to get the efi to work... the buggy got rewired.
    The Bostick®
    El Cajon, Ca.
    Default A little better... ish.
    Not exactly bitchen... but cleaning up what was there didn't come out too bad IMO.
    The Bostick®
    Nice clean up, looks like the zip ties properly "DCB" spaced out?
    are you charging "per" zip tie ?
    that reminds me, maybe next week you can do a couple things I need done.
    are those two terminal plugs I see down in the bilge ? My boat leaks to much to have connections that low, I'm going to need them towards the top of the bell housing along with a battery kill-switch.
