suction housing measurement
Results 1 to 5 of 5
    Default suction housing measurement
    what is the inside bore measurement of the older dominator suction housing that used the smaller od wear ring.?
    Senior Member SBS933's Avatar
    Jun 2012
    Quote Originally Posted by johnray069 View Post
    Older as in what years ?
    Believe Nothing you hear and 1/2 of what you see.
    PRE 1984, believe there was only 2 different od wear rings the "earlier" and the standard od wear ring that is used today. believe it is the same measurement as the a.t. conversion ring for the jacuzzi conversion kit. need the measurement of the inside diameter where the wear ring goes.
    DJG
    DJG is offline
    early early 7.550 serial number 1000-1050
    early 7.585 serial number up to 14400
    late berk/dom 7.750 serial number 14400 to current
    thanks for the help, that was what i was looking for.
