Considering Petronix
Results 1 to 8 of 8
    Default Considering Petronix or Accel???
    For my stock Ford 460 in a Spectra 20 (about 450 hours). The distributor is a vacuum advance single point. So, should I get the original igintor or the ignitor II, or stick to points. I read the posts with both good and bad comments, I am willing to try it. The boat is used for skiing and cruising, about 4000 RPM max.
    Also, what spark plugs and wires do you guys recommend.
    Thanks in advance!
    OK, I went to the store and found another unit - the Accel - as far as I can see it is similar to the petronix, but uses it's own rotor in the distributor. It is cheaper than the Ignitor II at only $70 vs. $119.
    Your thoughts and insight.
    Thanks again.
    Anaheim/BHC- the Shack
    I've run them both, and other than the II not frying if the key's left on, you won't notice much difference.
    Re-member Willie B's Avatar
    Lake Oroville Ca./N. Hollywood Ca.
    .....I run the II on an FE 406 Ford.....Don't buy the I,....For.. if you leave the key on reason,...sizzle!!!..............Get their high output coil also......
    Default Accel - points eliminator?
    I edited my post, but just in case, I went to the store and found another similar unit made by Accel. The only difference I could see is that it uses it's own rotor.
    Your insight???
    Thanks again.
    Senior Member Ken F's Avatar
    I've got two of the pertronix units, a mallory dist. for a BBF and a hi-output coil that are one-season used, but I'd sell them if you would be interested.
    I have two pertronix because I always carried a spare.
    Replaced it with MSD.
    Ken F
    The liberals are asking us to give Obama time. We agree and think 25 to life would be appropriate.
    use a BBC to pull a BBC devanwon's Avatar
    portland oregon
    I had the petronix II in my tahiti cruiser and it worked great never any issues, I have been told about the I though spring for the II. just my .02 cents
    So I ordered the ignitorII from pepboys today. I will be in Parker this coming weekend installing and trying it out. Thanks for the help. I will post back how it worked out.
    Blythe, Ca Riverbass's Avatar
    I am running a pertronix HEI and love it no problems it works all the way to 7000 rpm.
