Valve Cover Breather
Results 1 to 2 of 2
    Sep 2012
    Default Valve Cover Breather
    I just replaced the oil pump on my BBC because the spring broke decreasing pressure...I have roller rockers & stud girdle but no deflector plates in the cast aluminum valve covers. At higher rpm, over 3500 & up I'm getting oil out the breather with a new working PCV & breather...my question is I went with a Melling 77HV which gives me 60 lbs. a but 25% more volume over stock, do I need the deflectors or what?...Grommets are serious McMaster-Carr and everything "seems" like a tight fit......
    Thanks Guys
    Senior Member Sweet Pickle's Avatar
    Mar 2011
    Calimesa CA
    I run Moroso or Jegs Oil Separators/Breathers which require drilling a 1.25 hole in the cover. Works good with or without Evacuation System
Name:	Boat Engine 010.jpg
ID:	359842   Click image for larger version.
Name:	Nicks Misc 009.jpg
