460 knocking
Results 1 to 9 of 9
460 knocking
    Member Riverjunky08's Avatar
    Orange County/Big River/Bullhead/Parker
    Default 460 knocking
    I recently took my boat out over the weekend and I noticed a little smoking coming out of my driver side breather then later on in the day my engine developed a knocking. I know it’s a vague description but does anyone have any ideas what it might be??
    Quote Originally Posted by Riverjunky08 View Post
    assuming oil pressure stayed up I would say piston. Run a compression check. M
    Senior Member chrisbsanger's Avatar
    Grass Valley
    What if the oil presure dropped ? Then what could we assume ?
    Quote Originally Posted by chrisbsanger View Post
    Holed a piston, got debri on top of the piston and took out a rod bearing or shortened a rod and still took out the bearing. M
    Cantard 71hallett's Avatar
    snow bank
    I think like Mark said, your going to need to do a compresion check. I would also do a visial check on the valve train. Does it still run the same at the exception of the knock and smoke?
    Yeah. As soon as the I heard the noise I stopped the boat. Then I turned it back on and let it idle to the launch ramp. I couldn't hear the noise at idle and almost no smoke.
    Quote Originally Posted by ptz View Post
    beer in the valve cover ?
    detonation.
    broken ring land ?
    pull the plugs put a socket on the crank and rock it back and forth if you think it has a spun bearing.
    if it is spun,
    the knocking is usually the piston hitting the cylinder head.
    stock car truck oil pan ?
    i have a low hour used 460 engine im putting on craigs in few days.
    I believe its stock. I haven't touched that part of the engine yet so I don't know.
    If you would have revved it or put alittle load on it the noise may have reapeared. Still wondering about any change in the oil pressure???? M
    I didn't think to check the pressure. I was to concerned with the noise but I should have.
