Sleekcraft SST
Results 1 to 10 of 10
Sleekcraft SST
    Senior Member andyc's Avatar
    Feb 2010
    Valley of the Winds
    Default Sleekcraft SST
    Gearing up to install BBC in my SST. I'm a little confused on how engines where rigged in these hulls.
    I have all parts to do either a 3 point, 4 point, rail mount and even mercruiser type big threaded jobs with cast iron legs. Any suggestions and pix would be great.
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    Feb 2010
    Valley of the Winds
    Default Thanks-
    Heck-that post was started by my kid, I just couldn't find it. He changed his user name. Thanks again.
    bullhead city
    mine is in that thread, does yours have stringers on top of the tunnels or just the bottom like most
    Feb 2010
    Valley of the Winds
    Default stringers?
    I believe it is a standard layup. I also believe these hulls have no actual stringers. Is there any truth to this?
    seattle
    Quote Originally Posted by andyc View Post
    they don't have stringers! people add stringers to them! my cousin just did an SST last winter, he chose to add them........
    75 Eliminator
    Feb 2010
    Valley of the Winds
    Question solid build
    I figure that if hull was designed and built without stringers, then the structual integrity is in the lay up. It does have a deck/floor which I will be replacing. I bet the deck is one of the structual components. Any thoughts?
    bullhead city
    there is wood in the tunnels but I want to do stringers for the motor rails and 4 pt mounts, just putting the rails and pump brace made a difference feels stiffer
    Jul 2010
    Default engine mount for SST Tunnel
    I had the same issue when mounting my engine so I build my own rail stringer system using aluminim chanel with sst bolts epoxied into the boat
ID:	372289   Click image for larger version.
    Feb 2010
    Valley of the Winds
    Looks like alot of work done from one pix to the next. Pump change? Tom JBP told me he actually make a kit for this hull. So the bolts go in from the bottom an "nutted" at the rails?
