[Question] Carburetor
Results 1 to 12 of 12
Carburetor
    Aug 2013
    Granbury
    Default Carburetor
    Just bought a 75 Tahiti, new to the jet boat world. Needs a new carburetor, can anyone tell me what I need or recommendations?
    Senior Member ontheNOS's Avatar
    Jan 2012
    Inland Empire
    Some engine/boat info would help :-)
    Aug 2013
    Granbury
    Stock 460. Berkeley pump. 18ft
    Thats about all I have
    750dp
    Aug 2013
    Granbury
    Thanks, I appreciate the info.
    Before purchasing a new carb you might try giving John at C&J a call. He may be able to rebuild it for cheaper than buying a new one and if not, he'll probably be able to get you a great deal. Congrats on the new purchase.
    C & J Engineering
    Jan 2012
    St. Louis, MO
    Quote Originally Posted by Riomabe View Post
    Opinion: I'd just go to an 850 from the get-go. These things are running under load at all times, so it's hard to have "too much" carburetor. Your stock 460 might not use all of the capability, but for a few bucks more, you can have some margin for possible future upgrades to the 460.
    I've been running a QuickFuel M-850 for a couple of years on my 496 BBC. Had to change the power spring to eliminate a rich running condition at skiing speeds. Other than that, I've been happy with it. It gave me approx. 150 rpm over my old 750 Edelbrock.
    If you have an enclosed engine space (I doubt it), then be sure to use a USCG-approved marine carburetor. And replace your hose (use USCG-approved A-1 hose) while you're at it.
    Good luck. And, as others have said: "Welcome to the madness".
    whats on it now!!!?
    Apr 2010
    holley 780 vac secondaries...
    750dp
    X's 2 good all around choice with appropriate fuel pump !
    Quote Originally Posted by southwind74 View Post
    That carb will work with a rebuild and TUNE!!!! What I mean by TUNE is rejet and metering plate with the proper secondary spring. It's basic carb 101 tuning or dump a few bucks on a new carb and wind out doing the same thing! Good luck!
    Colorado Springs, Co.
    +1
    The 780 will work fine if you have a basically stock lake boat. The vac secondaries will work well too. I ran a 4150 750vac on my old jet's 454, quick change kit made it easy to dial in the secondaries. I had it set up so the secondaries would open around 3600. I could cruise around the lake all day on just the primaries.
    1978 Glastron/Carlson CV23; 429, Berk jet.
