The "A" in impellar?
Results 1 to 5 of 5
    Senior Member andyc's Avatar
    Feb 2010
    Valley of the Winds
    Default The "A" in impellar?
    I have several impellars. I searched this site to find my answer but no luck. I know that its common to find impellars that when re-cut are not usually re-stamped. My question is: How to ID an A from an AA in regards to what is stamped into the casting? Are the letters next to each other? I have some stamped A 2, A A but they dont sit next to each other. So are these A's or AA's ?
    Senior Member vmaxed's Avatar
    Sep 2010
    EAST LA (Lower Arkansas)
    Default by the edge
    See how the upper edge of vane is even with the impeller that's an A. If it sticks out beyond the face its a AA or bigger. If the edge of the vane angles in more its a A/B, B or smaller. I think the is a chart on JBP's site with dementions and angles.
ID:	369313   Click image for larger version.
    Pics help
    Feb 2010
    Valley of the Winds
    Default Here's the pix
    I have never uploaded pix so hope this works.
    My understanding that the one stamped A2 is an AA? and the other is a std A?
ID:	369409   Click image for larger version.
ID:	369385   Click image for larger version.
ID:	369393   Click image for larger version.
